1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Successfully locked memory using mlockAll
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 24 Nov 2015 10:22:07 -0200
 Hello, but these messages may appear to non root users, and are not really related to being root or not, but to the real time operations in libCom. For example:
[henrique.almeida@SOL1-HOST1 linux-x86]$ cp caget /tmp/
[henrique.almeida@SOL1-HOST1 linux-x86]$ cd /tmp/
[henrique.almeida@SOL1-HOST1 tmp]$ sudo setcap 'cap_sys_nice+ep cap_ipc_lock+ep' ./caget
[henrique.almeida@SOL1-HOST1 tmp]$ ./caget LNLS:ANEL:corrente
LNLS:ANEL:corrente             227.682
 In the example above, standard non-root user saw the debug message even though he's not root, only because I activated real time support.
 This looks like a design bug to me, because a helper library is writing on the standard error on behalf of the application when it was not asked for doing it. Can this feature be disabled ?
2015-11-23 19:44 GMT-02:00 Andrew Johnson <[email protected]>:
On 11/23/2015 01:20 PM, Henrique Dante de Almeida wrote:
>  Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6
> installation and after compiling, executing caget always returns
> the message "Successfully locked memory using mlockAll":
> [root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.585
> [root@SOL1-HOST1 linux-x86]# cd
> [root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.553
> (etc.)
> Can the message be removed ? Here is what seems to be the relevant
> commit:
> https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
Those messages will be printed to stderr if you run caget (or any other
program linked with our libCom library) as root. Using the root account
to run programs that don't need such privilege is a bad idea from a
computer security perspective though. Some sites do need to run certain
IOCs with root privilege to enable the real-time scheduler (which then
makes it desirable to lock the IOC code into physical RAM) or to access
certain I/O hardware from user-space, but in most cases we'd recommend
that you use a non-root account for programs like caget/caput/camonitor.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Re: Successfully locked memory using mlockAll Till Straumann
Successfully locked memory using mlockAll Henrique Dante de Almeida
Re: Successfully locked memory using mlockAll Andrew Johnson
Prev: Missaligned protocol rejected when using caPutLog Qiao Yusi
Next: Re: Missaligned protocol rejected when using caPutLog Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Successfully locked memory using mlockAll Andrew Johnson
Next: Re: Successfully locked memory using mlockAll Till Straumann
