1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Successfully locked memory using mlockAll
To: Henrique Almeida <[email protected]>, Andrew Johnson <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Tue, 24 Nov 2015 08:23:26 -0800
It has indeed nothing to do whether you execute as root or not
but depends on whether EPICS has the sufficient privilege to use
the real-time scheduler.
In many cases use of this scheduler is restricted but obviously
root always has sufficient privilege and such systems (without
additional measures) the simple formula is: executed as 'root'
EPICS will use the RT scheduler, executed as a normal user it won't.
We configure our real-time systems usually so that the user account
which starts EPICS IOCs does indeed have the privilege to use
the RT-scheduler. We do this by granting an unlimited hard boundary
for real-time priorities (setrlimit(RLIMIT_RTPRIO) or 'ulimit' from bash).
However, we also set the initial soft limit to zero.
This setup means that by default the user's EPICS (and other processes)
cannot use the RT scheduler (since the soft limit is 0).
If the user wants to spawn an RT process then they lift the soft limit
bash$  ulimit -S -r unlimited
and likewise for the amount of locked memory:
bash$ ulimit -S -l unlimited
Subsequently started processes can then use these resources which are
critical for real-time performance.
I don't know the setup of your system but you could simply try
ulimit -S -r 0
and then your EPICS clients (and other processes) should not
be able to use the RT scheduler (and will not try to mlockall).
The rationale behind all of this is that
 - since EPICS has the potential to operate as a real-time application
   it will try to do so if you let it (= if it determines it has sufficient privilege)
   assuming that was your intention
 - real-time execution requires all real-time critical data, stack and text to
   permanently reside in memory. Since it would put a significant burden on
   the programmer to manually identify all critical memory areas and
   selectively lock these the complete process is locked in memory.
   We have diskless system here with 1G of RAM and there haven't been
   real issues with lack of memory.
 - if EPICS determines it has not sufficient privilege to use the RT scheduler
   then it falls back on the vanilla scheduler and will not attempt to lock
   the process in memory.
I can also recommend to read this wiki page
https://wiki-ext.aps.anl.gov/epics/index.php/How_To_Use_Posix_Thread_Priority_Scheduling_under_Linux
HTH
- Till
On 11/24/2015 04:22 AM, Henrique Almeida wrote:
 Hello, but these messages may appear to non root users, and are not really related to being root or not, but to the real time operations in libCom. For example:
[henrique.almeida@SOL1-HOST1 linux-x86]$ cp caget /tmp/
[henrique.almeida@SOL1-HOST1 linux-x86]$ cd /tmp/
[henrique.almeida@SOL1-HOST1 tmp]$ sudo setcap 'cap_sys_nice+ep cap_ipc_lock+ep' ./caget
[henrique.almeida@SOL1-HOST1 tmp]$ ./caget LNLS:ANEL:corrente
LNLS:ANEL:corrente             227.682
 In the example above, standard non-root user saw the debug message even though he's not root, only because I activated real time support.
 This looks like a design bug to me, because a helper library is writing on the standard error on behalf of the application when it was not asked for doing it. Can this feature be disabled ?
2015-11-23 19:44 GMT-02:00 Andrew Johnson <[email protected]>:
On 11/23/2015 01:20 PM, Henrique Dante de Almeida wrote:
>  Hello, I'm testing EPICS base v 3.15 on a fresh Red Hat 6.6
> installation and after compiling, executing caget always returns
> the message "Successfully locked memory using mlockAll":
> [root@SOL1-HOST1 linux-x86]# ./caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.585
> [root@SOL1-HOST1 linux-x86]# cd
> [root@SOL1-HOST1 ~]# caget LNLS:ANEL:corrente
> LNLS:ANEL:corrente             161.553
> (etc.)
> Can the message be removed ? Here is what seems to be the relevant
> commit:
> https://code.launchpad.net/~mshankar/epics-base/memlock_linux/+merge/232466
Those messages will be printed to stderr if you run caget (or any other
program linked with our libCom library) as root. Using the root account
to run programs that don't need such privilege is a bad idea from a
computer security perspective though. Some sites do need to run certain
IOCs with root privilege to enable the real-time scheduler (which then
makes it desirable to lock the IOC code into physical RAM) or to access
certain I/O hardware from user-space, but in most cases we'd recommend
that you use a non-root account for programs like caget/caput/camonitor.
- Andrew
Light thinks it travels faster than anything but it is wrong.
No matter how fast light travels, it finds the darkness has
always got there first, and is waiting for it.
    -- Terry Pratchett, Reaper Man
Successfully locked memory using mlockAll Henrique Dante de Almeida
Re: Successfully locked memory using mlockAll Andrew Johnson
Re: Successfully locked memory using mlockAll Henrique Almeida
Prev: RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mark Rivers
Next: RE: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Successfully locked memory using mlockAll Henrique Almeida
Next: error: ‘dbChannel’ has no member named ‘final_dbr_type’ Henrique Dante de Almeida
