1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
To: "'Cusick, Martin-Lee'" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 9 Dec 2015 18:35:53 +0000
Hi Lee,
Can you send the complete output when you do the following at the top level of base-3.14.12.3.
setenv EPICS_HOST_ARCH linux-x86
make clean
make
Note in your original message you said:
>  I have the gcc-multilib package, and lib32, and I followed this advice:
>  base/configure/os/CONFIG_SITE.linux-x86.Common:
 > # T.S, 2006/09/05
>  # add -m32 so we create 32-bit code when
> # executing on 64-bit machine with EPICS_HOST_ARCH=linux-x86
> ARCH_DEP_CFLAGS+=-m32
> ARCH_DEP_CXXFLAGS+=-m32
> ARCH_DEP_LDFLAGS+=-m32
The tech-talk link you pointed to was for a very old release of base, 3.14.8 which is when 64-bit support was just beginning. You should NOT make those edits in 3.14.12.3, it is all taken care of in the standard distribution.  I build linux-x86 on a 64-bit Linux system all the time without any edits to CONFIG_SITE.linux-x86.Common.
From: Cusick, Martin-Lee [mailto:[email protected]]
Sent: Wednesday, December 09, 2015 12:19 PM
To: Mark Rivers; [email protected]
UNRESTRICTED / ILLIMITÉE
Hi Mark,
Thanks for the prompt reply.
I did have the correct links, but I found this out with some tinkering it was actually a missing g++ library that solved my problem.
I had to install g++-multilib, that solved the libstdc++ link issue.
My three builds built, but I know have a separate issue. Please review it to determine if I should post it to another subject.
base/bin:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls
linux-arm-rpi  linux-x86  linux-x86_64
ls arm:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls linux-arm-rpi/
acctst        casw               iocLogServer
aitGen        ca_test            makeBaseApp.pl
antelope      catime             makeBaseExt.pl
ascheck       convertRelease.pl  makeBpt
caConnTest    cvsclean.pl        makeIncludeDbd.pl
caDirServ     dbExpand           makeMakefile.pl
caEventRate   dbReadTest         makeTestfile.pl
caget         dbToMenuH          mkmf.pl
caget.pl      dbToRecordtypeH    munch.pl
cainfo        dos2unix.pl        registerRecordDeviceDriver.pl
cainfo.pl     e_flex             replaceVAR.pl
camonitor     excas              S99caRepeater
camonitor.pl  expandVars.pl      S99logServer
capr.pl       filterWarnings.pl  softIoc
caput         fullPathName.pl    useManifestTool.pl
caput.pl      genApps
caRepeater    installEpics.pl
Which looks complete.
Ls x86_64:
/usr/local/epics.bak/base-3.14.12.3/bin$ ls linux-x86_64
caput.pl      genApps
Good.
Ls x86:
convertRelease.pl  filterWarnings.pl  makeBaseExt.pl     mkmf.pl
cvsclean.pl        fullPathName.pl    makeIncludeDbd.pl  munch.pl
dos2unix.pl        installEpics.pl    makeMakefile.pl    replaceVAR.pl
expandVars.pl      makeBaseApp.pl     makeTestfile.pl    useManifestTool.pl
Missing a lot of tools here.
Please tell me your thoughts.
Thanks so much,
Lee
Sent: December-09-15 12:24 PM
To: Cusick, Martin-Lee; [email protected]
Subject: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
Are you sure you have installed both the 64-bit and 32-bit versions of the system library libstdc++.so?
Here are the files on my Fedora system:
7233436    0 lrwxrwxrwx   1 root     root           37 Apr 10  2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/libstdc++.so -> ../../../../lib64/libstdc++.so.6.0.16
7233434    0 lrwxrwxrwx   1 root     root           31 Apr 10  2012 /usr/lib/gcc/x86_64-redhat-linux/4.6.3/32/libstdc++.so -> ../../../../libstdc++.so.6.0.16
Note that there are both 64-bit and 32-bit versions of that library.
Do you find both 64-bit and 32-bit versions of libstdc++.so on your system?
From: [email protected] [mailto:[email protected]] On Behalf Of Cusick, Martin-Lee
Sent: Wednesday, December 09, 2015 9:00 AM
To: [email protected]
Subject: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
OFFICIAL USE ONLY / À USAGE EXCLUSIF
Hello,
I will start will giving some of the environment details:
Host Machine:
Ubuntu 12.04 (3.13.0-71-generic kernel) x86_64
I am building IOC's for 64 and 32-bit machines; I am also cross compiling for ARM (Raspberry Pi), with crosstools-ng.
The build is successful for 64 bit binaries and the 32-bit cross compile, but I keep getting an error for x86:
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.so when searching for -lstdc++
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.6/libstdc++.a when searching for -lstdc++
/usr/bin/ld: cannot find -lstdc++
collect2: ld returned 1 exit status
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/usr/local/epics.bak/base-3.14.12.3/src'
make: *** [src.install] Error 2
# T.S, 2006/09/05
Thanks you in advance for your help,
Lee
RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
Prev: Re: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Michael Davidsaver
Next: RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
Next: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
