1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ai RVAL via asyn + modbus: getting unsigned integer
Date: Mon, 14 Dec 2015 19:28:14 +0000
Please send the output of
dbpr Iso:GantryCouch:Collimator:Actual 10
Sent from my iPhone
> On Dec 14, 2015, at 11:22 AM, "[email protected]" <[email protected]> wrote:
> I did the experiment Mark suggested and found that drvModbusAsyn.c is working as
> expected - it returns small negative integers when small negative voltages are applied to the converter.  BUT in those cases RVAL is still reported as a large positive integer.  Details follow:
>> On Sat, 12 Dec 2015, Mark Rivers wrote:
>> You could add the following printf statement to drvModbusAsyn.c::readPlcInt and see what the output is for that value.
>>       case dataTypeInt16:
>>       result = (epicsInt16)value;
>> printf("readPlcInt, offset=%d, value=0x%x, result=%d (0x%x)\n", offset, value, result, result);
>>       break;
> I did that and got these results.  When Vin is a small positive value +0.002 V,
> value is a small positive integer and RVAL is a small positive integer:
> readPlcInt, offset=0, value=0x1, result=1 (0x1)
> dbgf Iso:GantryCouch:Collimator:Actual.RVAL
> DBR_LONG:           6         0x6
> (the voltage varies slightly between the printf and dbgf outputs)
> But when Vin is -0.008 V, value is a small negative integer BUT RVAL is a large positive integer:
> readPlcInt, offset=0, value=0xfff4, result=-12 (0xfffffff4)
> DBR_LONG:           65524     0xfff4
> So it seems RVAL is handled differently than value.  Is there some way to make
> RVAL behave like value?
> Jon Jacky
> PS - here are answers to Mark's other questions about MODBUS_DATA and asynReport
>> In your database for the ai record what is the drvInfo field in the INP link? Is it still MODBUS_DATA? If so, that should be fine.
> Yes, dbpr reports the INP field is INP:INST_IO @asynMask(CollimCouch, 0, 16, 1000)MODBUS_DATA
>> Please send the output of the following command:
>> asynReport(1, "CollimCouch")
> I believe addr 0 is connected to Vin in the output shown above.
> epics> asynReport(1, "CollimCouch")
> CollimCouch multiDevice:Yes canBlock:Yes autoConnect:Yes
>    enabled:Yes connected:Yes numberConnects 1
>    nDevices 6 nQueued 0 blocked:No
>    asynManagerLock:No synchronousLock:No
>    exceptionActive:No exceptionUsers 0 exceptionNotifys 0
>    traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
>    addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
>        exceptionActive No exceptionUsers 0 exceptionNotifys 0
>        blocked No
>    addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
>        blocked No
>    addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
>        blocked No
>    addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
>        blocked No
>    addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
>        blocked No
>    addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
>        blocked No
> modbus port: CollimCouch
>    asynOctet server:   AcromagCollimCouch
>    modbusSlave:        0
>    modbusFunction:     4
>    modbusStartAddress: 00
>    modbusLength:       011
>    plcType:            AcromagXT1221
>    I/O errors:         0
>    Read OK:            2207
>    Write OK:           0
>    pollDelay:          0.100000
>    Time for last I/O   1 msec
>    Max. I/O time:      7 msec
>    Time per hist. bin: 1 msec
RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
RE: ai RVAL via asyn + modbus: getting unsigned integer jon
Prev: RE: ai RVAL via asyn + modbus: getting unsigned integer jon
Next: RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
