1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: running multiple iocs on raspberry 2
To: [email protected]
Date: Tue, 12 Jan 2016 13:45:40 +0100
Hi
I am setting up a measuerement setup consisting of three individual devices, which i would like to control with EPICS, running the IOC on a Raspberry Pi. Communication with each of the devices is done using altogether three USB-Serial converter, and based on StreamDevice.
I already have working IOCs for each individual device.
Now:
If i would like to run the full setup simultaneously:
Is it better to run the three IOCs individual on the Raspberry, one for each device ? And relying on Linux for the Multitasking ? Or is it preferable to run only a single IOC, and load the three database .dbd files into the same IOC, Initializing all three Serial ports in the same st.cmd startup file ???
The Raspberry2 has a quadcore CPU, so I could imagine, that running three individual IOCs might give better performance, since three cores are used ? But isn't there a problem to run more than one IOC in parallel ?
Any advice welcome !
Best regards.
Christian
RE: running multiple iocs on raspberry 2 Mark Rivers
Prev: RE: Cost effective solution for monitor a large number of temperatures w EPICS Mark Rivers
Next: RE: running multiple iocs on raspberry 2 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Device Support for I2C and GPIO -> StreamDevice Florian Feldbauer
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
