Either way should work. If you run 3 devices in one IOC they will still use multiple threads/cores for some things, for example each asynSerialPort driver will run in its own thread. There is no problem to run multiple IOCs on the same computer either.
From: [email protected] [[email protected]] on behalf of Christian Pauly [[email protected]]
Sent: Tuesday, January 12, 2016 6:45 AM
To: [email protected]
Subject: running multiple iocs on raspberry 2
Hi
I am setting up a measuerement setup consisting of three individual
devices, which i would like to control with EPICS, running the IOC on a
Raspberry Pi. Communication with each of the devices is done using
altogether three USB-Serial converter, and based on StreamDevice.
I already have working IOCs for each individual device.
Now:
If i would like to run the full setup simultaneously:
Is it better to run the three IOCs individual on the Raspberry, one for
each device ? And relying on Linux for the Multitasking ?
Or is it preferable to run only a single IOC, and load the three
database .dbd files into the same IOC, Initializing all three Serial
ports in the same st.cmd startup file ???
The Raspberry2 has a quadcore CPU, so I could imagine, that running
three individual IOCs might give better performance, since three cores
are used ? But isn't there a problem to run more than one IOC in parallel ?
Any advice welcome !
Best regards.
Christian
- Re: running multiple iocs on raspberry 2 Ralph Lange
- running multiple iocs on raspberry 2 Christian Pauly
Re: Device Support for I2C and GPIO Jeong Han Lee
<2016>
2025
2026
<2016>
2025
2026
