1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrfioc2 error at uTCA platform
To: 김지화(빔라인장치팀) <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 8 Mar 2016 03:05:53 +0000
Hi Jihwa,
Hmm, from the data you shared I can tell that
a) your PMC should indeed be supported
b) mrfioc2 detects the card and starts talking to it but in the process
of setting things up something goes wrong
c) I'm not sure if the order of the messages printed to the IOC shell
corresponds to the order of execution. Unfortunately some of the
messages are printed using errlogPrintf (which uses stderr) and printf
(which uses stdout)... You might want to consider converting the printfs
to errlogPrintfs to be sure.
d) find_uio_number is definitely failing here. Can you please check if
you have a directory like /sys/bus/pci/devices/####:0e:01.0/uio/uio#?
Which versions of mrfioc2 and devlib2 are you using? Can you confirm
that your mrf kernel module has been built from the same source
repo/tarball as the mrfioc2 device support?
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: mrfioc2 error at uTCA platform Konrad, Martin
Prev: Re: mrfioc2 error at uTCA platform Michael Davidsaver
Next: Array of strings with asyn? Ryan Pierce
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Next: Request for help on CSS Anindya Roy
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
