Hi Michael,
Thank you for your many advice and the Vadatech engineer helped how to delete “pci_mrfevr.ko” delete.
Now mrfioc2 IOC successfully loaded and running at the uTCA PMC platform.
[root@amc725 ~]# cd /lib/modules/3.10.0-229.rt56.162.el6rt.x86_64/extra/
[root@amc725 extra]# ls
daq_series.ko mrf.ko pci_mrfevg.ko pci_mrfevr.ko sm750fb.ko
[root@amc725 extra]# rm pci_mrfevr.ko
After reboot...
[root@amc725 ~]# lsmod | grep mrf
mrf 13648 0
uio 19175 1 mrf
parport 40636 1 mrf
IOC reboot status
mrmEvrSetupPCI("PMCEVR",0xe,1,0)
Device PMCEVR 14:1.0
Using IRQ 16
FWVersion 0x11000007
Found version 7
Found SFP Strangeness 00070403
PMC Out FP:3 FPUNIV:0 RB:0 IFP:1
EVR FIFO task start
epics> dbior
Driver: ntpShared
Driver is not active
Driver: drvEvrMrm
=== Begin MRF EVR support ===
--- EVR PMCEVR ---
Model: 00000001 Version: 00000007
Clock: 119.000000 MHz
=== End MRF EVR support ===
Driver: drvEvgMrm
=== Begin MRF EVG support ===
=== End MRF EVG support ===
epics>
-Jihwa
Control & DAQ
Beamline contrsruction team
Beamline Division
PAL-XFEL Project
Pohang Accelerator Laboratory
80 Jigokro-127-Beongil, Nam-gu,
Pohang, Gyeongbuk 37673, Korea
TEL: 82-54-279-1102
Cellphone: 82-10-8564-0318
보낸 사람: [email protected] <[email protected]> 대신 김지화(빔라인장치팀) <[email protected]>
보낸 날짜: 2016년 3월 12일 토요일 오전 6:03
받는 사람: Michael Davidsaver; [email protected]; [email protected]
제목: RE: mrfioc2 error at uTCA platform
Hi Michael,
When boot time automatically loaded SLAC MRF "pci_mrfevr".
mrf 13648 0
uio 19175 1 mrf
parport 40636 1 mrf
pci_mrfevr 53687 0
I manually removed.
[root@amc725 opt]# /sbin/rmmod pci_mrfevr
[root@amc725 opt]# lsmod | grep mrf
mrf 13648 0
uio 19175 1 mrf
parport 40636 1 mrf
Restarted mrfioc2 but same error.
Using IRQ 16
Failed to open uio device for PCI device 0000:0e:01.0: No such file or directory
Failed to enable interrupt
How do I disable/remove this "pci_mrfevr" ?
-Jihwa
보낸 사람: Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 3월 11일 금요일 오후 11:18
받는 사람: 김지화(빔라인장치팀); [email protected]; [email protected]
제목: Re: mrfioc2 error at uTCA platform
On 03/10/2016 11:58 PM, 김지화(빔라인장치팀) wrote:
> Hi Michael,
> I've attached system information.
> Module Size Used by
> mrf 13648 0
> uio 19175 1 mrf
> parport 40636 1 mrf
> pci_mrfevr 53687 0
This shows that both kernel modules are loaded. To simplify
troubleshooting please ensure that only the 'mrf' module is loaded and
not 'pci_mrfevr'.
Only one linux driver can be attached to a particular PCI device. This
will typically be the first one loaded, in this case 'pci_mrfevr'. I
should also note that, with modern Linux drivers, having to manually
create a file in /dev/ is a sure sign that something is wrong.
- Re: mrfioc2 error at uTCA platform Konrad, Martin
- RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
- Re: mrfioc2 error at uTCA platform Michael Davidsaver
RE: Questions about medm3.19 problem on fedora 20 64bit Mark Rivers
Re: parametric PV save/restore Jack
<2016>
2025
2026
<2016>
2025
2026
