1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mrfioc2 error at uTCA platform
To: Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Mar 2016 21:03:18 +0000
Hi Michael,
When boot time automatically loaded SLAC MRF "pci_mrfevr".
 [root@amc725 ~]# lsmod | grep mrf
 mrf                    13648  0
 uio                    19175  1 mrf
 parport                40636  1 mrf
 pci_mrfevr             53687  0
 I manually removed.
 [root@amc725 opt]# /sbin/rmmod pci_mrfevr
[root@amc725 opt]# lsmod | grep mrf
 mrf                    13648  0
 uio                    19175  1 mrf
 parport                40636  1 mrf
 Restarted mrfioc2 but same error.
mrmEvrSetupPCI("PMCEVR",0xe,1,0)
 Device PMCEVR  14:1.0
 Using IRQ 16
 Failed to open uio device for PCI device 0000:0e:01.0: No such file or directory
 Failed to enable interrupt
 How do I disable/remove this "pci_mrfevr" ?
-Jihwa
보낸 사람: Michael Davidsaver <[email protected]>
보낸 날짜: 2016년 3월 11일 금요일 오후 11:18
받는 사람: 김지화(빔라인장치팀); [email protected]; [email protected]
제목: Re: mrfioc2 error at uTCA platform
On 03/10/2016 11:58 PM, 김지화(빔라인장치팀) wrote:
> Hi Michael,
> I've attached system information.
>  Module                  Size  Used by
>  mrf                    13648  0
>  uio                    19175  1 mrf
>  parport                40636  1 mrf
>  pci_mrfevr             53687  0
This shows that both kernel modules are loaded.  To simplify
troubleshooting please ensure that only the 'mrf' module is loaded and
not 'pci_mrfevr'.
Only one linux driver can be attached to a particular PCI device.  This
will typically be the first one loaded, in this case 'pci_mrfevr'.  I
should also note that, with modern Linux drivers, having to manually
create a file in /dev/ is a sure sign that something is wrong.
RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Re: mrfioc2 error at uTCA platform Konrad, Martin
Re: mrfioc2 error at uTCA platform Michael Davidsaver
Prev: EPICS Archiver Appliance web interface error 김지화(빔라인장치팀)
Next: Re: stream protocol question: ASCII hex to 32-bit float Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrfioc2 error at uTCA platform Michael Davidsaver
Next: RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
