1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mrfioc2 error at uTCA platform
To: 김지화(빔라인장치팀) <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 11 Mar 2016 09:18:32 -0500
On 03/10/2016 11:58 PM, 김지화(빔라인장치팀) wrote:
> Hi Michael,
> I've attached system information.
> [root@amc725 ~]# lsmod
>  Module                  Size  Used by
>  mrf                    13648  0
>  uio                    19175  1 mrf
>  parport                40636  1 mrf
>  pci_mrfevr             53687  0
This shows that both kernel modules are loaded.  To simplify
troubleshooting please ensure that only the 'mrf' module is loaded and
not 'pci_mrfevr'.
Only one linux driver can be attached to a particular PCI device.  This
will typically be the first one loaded, in this case 'pci_mrfevr'.  I
should also note that, with modern Linux drivers, having to manually
create a file in /dev/ is a sure sign that something is wrong.
RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Re: mrfioc2 error at uTCA platform Konrad, Martin
Re: mrfioc2 error at uTCA platform Michael Davidsaver
Prev: RE: Show alarms, events and measurements from DSP in CS-Studio and generate files with this data Mark Rivers
Next: LLRF / EPICS Engineer wanted bob dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
Next: RE: mrfioc2 error at uTCA platform 김지화(빔라인장치팀)
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
