Hi Carlos,
I don't use alarms a lot, but here is one example that uses alarms on the mca record. When the value of the deadtime is above 70 there is a HIHI alarm, which has severity MAJOR, above 40 is HIGH alarm which has severity MINOR, etc.
https://github.com/epics-modules/mca/blob/master/mcaApp/Db/mca.db
These alarm values are used to set the color of a bar graph shown under the label DeadTime on this plot
https://github.com/epics-modules/mca/blob/master/documentation/mca.png
Here is another example with some bi records that set the severity (ZSV, OSV) to MINOR or MAJOR to indicate status or problems.
https://github.com/areaDetector/ADCore/blob/master/ADApp/Db/NDFile.template
Those are used on this screen to set the colors of fields such as those labeled Enable, Exists, Write status, etc. on this screen:
https://github.com/areaDetector/ADCore/blob/master/documentation/NDFileJPEG.png
In your case how is the PLC sending the alarm status back to EPICS? Via a bit in a Modbus register? If so then you can set the ZSV and OSV of the bi record for that bit to the appropriate value (NO_ALARM, MINOR, MAJOR, etc.). That alarm status can then be used in your CSS display to indicate a problem with colors or change the visibility of some part of the display.
From: [email protected] [[email protected]] on behalf of Carlos Gómez Martinez [[email protected]]
Sent: Friday, March 11, 2016 3:29 AM
To: [email protected]
Subject: Show alarms, events and measurements from DSP in CS-Studio and generate files with this data
Hi ,
I am Carlos from Spain and I am developing an HMI, it consists of:
A DSP sends measurements, alarms and events through modbus addresses, these data are converted to EPICS and displayed on screen with CSS. The "brain" of the project is the DSP, ie, alarms are not made by epics, alarms are generated by the DSP and the cs-studio is only displayed if there is failure, if there is no fault, measures etc .. I would know how these failures can be collected, events and actions and how I can build a table in CS-Studio where these data to be displayed and also to generate a file with this data.
Carlos
- Show alarms, events and measurements from DSP in CS-Studio and generate files with this data Carlos Gómez Martinez
Re: mrfioc2 error at uTCA platform Michael Davidsaver
<2016>
2025
2026
Re: Show alarms, events and measurements from DSP in CS-Studio and generate files with this data Kasemir, Kay
<2016>
2025
2026
