1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn: what if a driver wants to force callbacks?
To: [email protected]
Cc: "[email protected] Talk" <[email protected]>
Date: Thu, 26 May 2016 23:49:53 -0300
I don't think so, I had this problem on Wednesday while writing an areaDetector IOC that updates a waveform record whenever a new image is saved. If the same file name is used twice in a row, the second callback does not emit a monitor event. I'm using EPICS base 3.16 and asyn and areaDetector github master branch.
Em 26/05/2016 10:08, "Mark Davis" <[email protected]> escreveu:
On 5/26/2016 1:52 AM, Torsten Bögershausen wrote:
I remember that Mark Rivers had said something about changing it so that a callback would happen for parameters for which the appropriate setXxxParam() function was called, even if the value had not changed.  And I THINK that it made it in to one of the more recent versions, but if so, I don't remember which one.
Mark Davis, FRIB/NSCL
To my knowledge,
there is no update.
In our driver, we do it like this:
    /* If not moving, trigger a record processing at low rate */
    if (!nowMoving) setDoubleParam(pC_->motorPosition_, newPositionInSteps + 1);
    setDoubleParam(pC_->motorPosition_, newPositionInSteps);
And I added a test case:
https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
Out of curiosity:
Which kind of device are you using ?
On 25/05/16 23:50, Ford, Christopher wrote:
In 2015 there was some discussion on Tech-Talk about how to force a callback for a parameter that had not changed values.
Mark Rivers suggested a work-around, as shown below.
I wonder if anyone has an update on the situation since then?  Has any other method appeared?  Or did you have success with the work-around?
 -Chris Ford, SLAC
On16 Nov 2015 Mark Rivers writes:
If a driver wants to force a callback there is a method that does not require any changes to the base classes, e.g. exposing statusChanged_ as protected or adding a new
isMotorRecordnowFilterButAlwaysProcess_ flag.  The driver simply needs to set a parameter to a different value from present and then back to its current value, for example
 setDoubleParam(pC_->motorPosition_(position+1.);
 setDoubleParam(pC_->motorPosition_(position);
 callParamCallbacks();
Mark Davis
NSCL/FRIB Control Systems Software Engineer
[email protected]
Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
RE: Area Detector question Mark Rivers
asyn: what if a driver wants to force callbacks? Ford, Christopher
Re: asyn: what if a driver wants to force callbacks? Mark Davis
Prev: Re: asyn build on cygwin fails Ana Malagon
Next: Oceanoptics MAYApro Spectrometer giles.knap
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn: what if a driver wants to force callbacks? Mark Davis
Next: Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
