1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn: what if a driver wants to force callbacks?
To: Henrique Almeida <[email protected]>, <[email protected]>
Cc: "[email protected] Talk" <[email protected]>
Date: Fri, 27 May 2016 09:42:43 +0200
To my understanding,
we are talking about 3 different things:
a) an asyn record
b) a motor Record
c) Area Detector
I can only talk about b), and there is no update,
you still need a workaround in the driver, at least for now.
How the area detector is related to the motor update, I don't know.
HTH
On 27/05/16 04:49, Henrique Almeida wrote:
I don't think so, I had this problem on Wednesday while writing an areaDetector
IOC that updates a waveform record whenever a new image is saved. If the same
file name is used twice in a row, the second callback does not emit a monitor
event. I'm using EPICS base 3.16 and asyn and areaDetector github master branch.
Em 26/05/2016 10:08, "Mark Davis" <[email protected] <mailto:[email protected]>>
escreveu:
    On 5/26/2016 1:52 AM, Torsten Bögershausen wrote:
    I remember that Mark Rivers had said something about changing it so that a
    callback would happen for parameters for which the appropriate
    setXxxParam() function was called, even if the value had not changed.  And
    I THINK that it made it in to one of the more recent versions, but if so, I
    don't remember which one.
    Mark Davis, FRIB/NSCL
    To my knowledge,
    there is no update.
    In our driver, we do it like this:
        /* If not moving, trigger a record processing at low rate */
        if (!nowMoving) setDoubleParam(pC_->motorPosition_,
    newPositionInSteps + 1);
        setDoubleParam(pC_->motorPosition_, newPositionInSteps);
    And I added a test case:
    https://github.com/EuropeanSpallationSource/MCAG_Base_Project/blob/master/epics/test/500_DLY-STOP.py
    Out of curiosity:
    Which kind of device are you using ?
    On 25/05/16 23:50, Ford, Christopher wrote:
    In 2015 there was some discussion on Tech-Talk about how to force a
    callback for a parameter that had not changed values.
    Mark Rivers suggested a work-around, as shown below.
    I wonder if anyone has an update on the situation since then?  Has any
    other method appeared?  Or did you have success with the work-around?
     -Chris Ford, SLAC
    On16 Nov 2015 Mark Rivers writes:
    If a driver wants to force a callback there is a method that does not
    require any changes to the base classes, e.g. exposing statusChanged_
    as protected or adding a new
    isMotorRecordnowFilterButAlwaysProcess_ flag.  The driver simply needs
    to set a parameter to a different value from present and then back to
    its current value, for example
     setDoubleParam(pC_->motorPosition_(position+1.);
     setDoubleParam(pC_->motorPosition_(position);
     callParamCallbacks();
    Mark Davis
    NSCL/FRIB Control Systems Software Engineer
a
Re: asyn: what if a driver wants to force callbacks? Mark Rivers
Area Detector question Jörn Wüstenfeld
RE: Area Detector question ulrik.pedersen
RE: Area Detector question Mark Rivers
asyn: what if a driver wants to force callbacks? Ford, Christopher
Re: asyn: what if a driver wants to force callbacks? Torsten Bögershausen
Re: asyn: what if a driver wants to force callbacks? Mark Davis
Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
Prev: Oceanoptics MAYApro Spectrometer giles.knap
Next: EPICS Base 3.15.4 released Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asyn: what if a driver wants to force callbacks? Henrique Almeida
Next: Re: asyn: what if a driver wants to force callbacks? Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
