1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance stuck in "Initail sampling" state
Date: Tue, 21 Jun 2016 18:39:28 +0000
>> I also changed the  “appliance.xml” file to match the quickstart demo version
The quickstart.sh and single_machine_install.sh are fundamentally two different deployment models. The "quickstart.sh" runs all the WAR files in a single Tomcat instance; thus all the ports in your appliance.xml will be 17665.
The "single_machine_install.sh" uses four separate tomcat instances; one each for each of the components.  Your "sampleStartup.sh" will start up four different tomcat's; each of which listen on different ports. This is probably the reason why you are getting this exception
java.io.IOException: Invalid status calling http://localhost:17665/engine/bpl/getVersion. Got 404Not Found
I would first try to reuse you original appliances.xml. Make sure the four component start up correctly without exceptions first.
If you need more help, ping feel free to ping me offline.
Murali
Prev: Archiver Appliance stuck in "Initail sampling" state rory.clarke
Next: Re: IOCs under procServ as system services under systemd? S. Banerian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Archiver Appliance stuck in "Initial sampling" state rory.clarke
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
