1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOCs under procServ as system services under systemd?
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 21 Jun 2016 13:33:06 -0700
I have been trying to get a systemd service to work, and almost had
something working, but observed systemd errors: status failed but ioc
running, systemctl stop failing to stop the service.
Based on what Nick has below, I changed (added) just one flag to my
ExecStart line with procServ, i.e.  ' -f ' and I now have a functioning
single-ioc service.
our bare-bones service file has this:
[Unit]
Description=start IOC via procserv
Requires=network.target
After=network.target auditd.service
ConditionFileIsExecutable=/usr/bin/procServ
ConditionFileIsExecutable=/usr/local/ops/iocBoot/ioccontrol/st.cmd
ConditionDirectoryNotEmpty=/usr/local/ops
RequiresMountsFor=/usr/local/epics /usr/local/ops
[Service]
EnvironmentFile=-/usr/local/ops/etc/epics.env
ExecStart=/usr/bin/procServ -f -L /usr/local/ops/var/procioc.log -p
/run/ioc.pid -l $PROCSERV_REMOTE_PORT $PROCSERV_LOCAL_PORT
ExecStop=/bin/kill -9 ` cat /run/ioc.pid`
KillMode=process
Restart=on-failure
User=ioc
[Install]
WantedBy=multi-user.target
where the EnvironmentFile contains many common variables and also the
$PROCSERV* variables.
Thanks to Nick for that ' -f ' flag
stefani
On 06/21/2016 01:17 AM, Niklas Claesson wrote:
> I do, but it is a bit special since I automatically create services based on the contents of a directory.
> I have a service template that looks like this (will create one service per IOC):
> ​[Unit]
> Description=IOC: %I
> After=rc-local.service
> [Service]
> User=ioc
> # Only execute IOC if st.cmd exists
> AssertPathExists=/opt/startup/ioc/%H/%i/st.cmd
> # Execute StartPre with root permissions
> PermissionsStartOnly=true
> ExecStartPre=/bin/mkdir -p /var/log/procServ
> ExecStartPre=/bin/chown -R ioc:ioc /var/log/procServ
> ExecStartPre=/bin/mkdir -p /var/run/procServ/%i
> ExecStartPre=/bin/chown -R ioc:ioc /var/run/procServ/%i
> EnvironmentFile=/opt/startup/ioc/%H/%i/env.sh
> # Run procServ with user ioc
> ExecStart=/usr/bin/procServ --allow -f -L /var/log/procServ/out-%i -i ^C^D -c /var/run/procServ/%i ${PROCSERV_PORT} ${EPICS_MODULES_PATH}/environment/${ENVIRONMENT_VERSION}/${BASE}/bin/${EPICS_HOST_ARCH}/iocsh /opt/startup/ioc/%H/%i/st.cmd -n %i
> [Install]
> and then I have a "master" service which creates all the IOC services:
> [Unit]
> Description=IOC Starter
> After=ess-boot.service
> [Service]
> Type=oneshot
> ExecStart=/bin/sh -c 'for i in /opt/startup/ioc/%H/*; do /bin/systemctl start ioc@$${i##*/}.service; done'
> Sources are here: https://bitbucket.org/europeanspallationsource/m-epics-environment/src/4e7777bf062f5cf8f895a8e79775c0360600149e/meta/systemd/system/?at=master
> Cheers,
> Niklas
>> All,
>> As more and more people are facing a move of Linux based IOC hosts
>> towards systemd...
>> Does anyone has a working setup for systemd, that manages an IOC under
>> procServ as a system service?
>> I would really like to have a standard setup (in the procServ contrib
>> dir and on the EPICS Wiki) to allow sharing what people develop on top
>> of it.
>> Any help is appreciated!
>> Thanks,
>> ~Ralph
Stefani Banerian
UW Clinical Cyclotron
UW School of Medicine
UW Box 356043
206-598-0302
gpg key 6642E7EE
fingerprint = BD13 875D 2D03 5E1D 1E3B  8BF7 F4B8 63AD 6642 E7EE
IOCs under procServ as system services under systemd? Ralph Lange
Re: IOCs under procServ as system services under systemd? Niklas Claesson
Prev: Re: Archiver Appliance stuck in "Initail sampling" state Shankar, Murali
Next: RE: Archiver Appliance stuck in "Initial sampling" state rory.clarke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOCs under procServ as system services under systemd? Niklas Claesson
Next: Re: IOCs under procServ as system services under systemd? Konrad, Martin
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
