1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: question of data conversion
To: Remi Faure <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 27 Jun 2016 19:00:34 +0200
On June 27, 2016 1:59:40 PM GMT+02:00, Remi Faure <[email protected]> wrote:
Hi again,
I Tested ASLO and AOFF without success with LINR=LINEAR.
I changed LINR=SLOPE, now it works fine.
Thank you for quick help!
Remi FAURE
Le 27/06/2016 à 12:32, bob dalesio a écrit :
And set LINR appropriately.
This chapter of the Record Reference Manual are also appropriate:
On Mon, Jun 27, 2016 at 5:32 AM, Ralph Lange <[email protected]> wrote:
Hi Remi,
Have a look at the "Convert and Write Parameters" section of the ao record documentation at
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Analog_Output#Convert_and_Write_Parameters
LOPR/HOPR are giving hints about the expected value range to applications, they do not affect conversion.
You should use EGUL/EGUF or ESLO/EOFF.
Cheers,
~Ralph
On 27/06/2016 10:40, Remi Faure wrote:
I have a simple question. All the examples I found about EPICS data convertion starts from raw value (DAQ) to engineering unit value.
I don't arrive to make the opposite in a simple way. I want to write a numerical data from CSS boy to an output value of a plc.
For instance I tried a longout or ao record , wich is passing directly the 0/4095 value correctly. When I try to pass a 0/100% value and try convert it in 0/4095 with LOPR, HOPR fields it fails.
In attachement a simple drawing of what I want to make here.
Thank you in advance for help.
Remi FAURE
LPSC Grenoble
Should be ESLO and EOFF, though. (See documentation.)
Cheers,
~Ralph
question of data conversion Remi Faure
Re: question of data conversion Ralph Lange
Re: question of data conversion bob dalesio
Re: question of data conversion Remi Faure
Prev: Re: IOCs under procServ as system services under systemd? Andrew Johnson
Next: Re: IOCs under procServ as system services under systemd? Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question of data conversion Remi Faure
Next: Call to assert failed - EPICS Pedro Mantovani Antunes
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
