1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOCs under procServ as system services under systemd?
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 27 Jun 2016 17:48:02 +0000
Hi Andrew,
> Has anybody produced a systemd unit file for running the caRepeater?
Nope. But something along the following lines should get you started:
[Unit]
Description=EPICS CA Repeater
Requires=network.target
After=network.target
[Service]
ExecStart=/usr/bin/caRepeater
Restart=always
User=carepeater
[Install]
WantedBy=multi-user.target
> It should be possible to extend the CA Repeater client with an option
> to accept an open socket
Are you suggesting to replace the caRepeater autostart functionality by
systemd's socket activation in the long run?
Cheers,
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: IOCs under procServ as system services under systemd? Andrew Johnson
IOCs under procServ as system services under systemd? Ralph Lange
Re: IOCs under procServ as system services under systemd? Niklas Claesson
Re: IOCs under procServ as system services under systemd? Konrad, Martin
Prev: Re: question of data conversion Ralph Lange
Next: Re: IOCs under procServ as system services under systemd? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOCs under procServ as system services under systemd? Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
