1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Post numbers used by CA client
To: Stephen Molloy <[email protected]>, Ralph Lange <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Mon, 4 Jul 2016 22:41:49 +0000
> I¹m getting complaints about identical PV¹s being found on multiple
> servers, but I think this is a side effect of running on a VM.
You will also get that complaint if you run the server and client on the same machine, and if the machine has more than 1 network card.  You can eliminate the complaint by setting EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=xxx.yyy.zzz.255 where xxx.yyy.zzz.255 is the broadcast address of the subnet you want to use for Channel Access.
From: [email protected] [[email protected]] on behalf of Stephen Molloy [[email protected]]
Sent: Monday, July 04, 2016 4:09 PM
To: Ralph Lange; EPICS Tech-Talk
Subject: Re: Post numbers used by CA client
Thanks Ralph,
Your comment on UDP & TCP was the clue I needed.  I had opened 5064 &
5065, but only for TCP connections.  Opening them up for UDP as well
allowed external connections.  Using the following command to run the
docker container did the trick,
docker run -i -t ‹rm -p 5064:5064 -p 5064:5064/udp -p 5065:5065 -p
5065:5065/udp sdmolloy/ubuntu-playground:latest /bin/bash
Thanks for your help,
Steve
On 04/07/16 17:02, "Ralph Lange" <[email protected]> wrote:
>Hi Steve,
>A CA client uses ephemeral ports as originating port numbers, correct.
>Ephemeral port numbers are indeed random, and cannot be predicted
>reliably.
>However, if your container contains an IOC (CA server), opening ports
>5064&5065 (in the default setup) for both TCP and UDP should allow any
>client outside the container to connect. (Not much different to a
>container with a web service published at port 80.)
>The CA client in the container would still use ephemeral port numbers
>for outgoing connections - do you need to publish those?
>Cheers,
>~Ralph
>On 04/07/2016 16:43, Stephen Molloy wrote:
>> I¹m trying to build a Docker container for quick set-up and tear-down
>> of EPICS instances, and I¹ve run into a problem.  A CA client outside
>> the container, but on the same host, cannot see any PV¹s served from
>> inside the container.
>> Looking at the network traffic with Wireshark, I can see that the
>> server uses ports 5064 & 5065 as expected, but the ports used by the
>> client seem to be relatively random.  If I could predict them, or
>> (even better) force them to be specific ports, then I could expose
>> those ports in the Docker container and (hopefully) the client and
>> server could communicate properly.
>> Or perhaps this isn¹t the problem, and there is some other network
>> issue getting in my way.
>> (I¹ve successfully run several EPICS installations on this network and
>> from this computer, so I am confident that this is an issue with the
>> Docker set-up.)
>> Hopefully I¹m on the right track with my thinking, and hopefully
>> someone can let me know how to proceed from here?
>> In case you¹re interested, I¹m documenting my work on my blog ‹
>> http://www.smolloy.com/2016/07/easy-epics-implementation-with-docker/
>> Thanks (again) for your time,
>> Steve
Post numbers used by CA client Stephen Molloy
Re: Post numbers used by CA client Ralph Lange
Re: Post numbers used by CA client Stephen Molloy
Prev: Re: Post numbers used by CA client Stephen Molloy
Next: MRF EVG, EVR, and EVM's Linux Kernel modules Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Post numbers used by CA client Andrew Johnson
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
