That is your problem. You need to edit your login script to add /epics/base/bin/linux-x86_64 to your PATH environment variable. Then it will find camonitor when you type that command.
Sent: Friday, July 22, 2016 4:36 PM
To: Mark Rivers; [email protected]
Subject: Re: How to configurate MCA for Octave
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
2016-07-23 0:29 GMT+03:00 Mark Rivers <[email protected]>:
I suspect the files are in base, but base is not in your path. Please send the output of
echo $PATH
What version of EPICS are you using? What does
ls -l /epics/base/bin/linux-x86_64
I was under the impression that caget/caput/camonitor and such had versions in base for quite some time.
It's on that path (/epics/base/bin/linux-x86_64). But when I type "which camonitor" , there is no response like
yours,sir.
- Re: How to configurate MCA for Octave Hulusi Öz
- How to configurate MCA for Octave Hulusi Öz
- Re: How to configurate MCA for Octave Eric Norum
- RE: How to configurate MCA for Octave Mark Rivers
Re: How to configurate MCA for Octave Pete Jemian
<2016>
2025
2026
<2016>
2025
2026
ANJ, 22 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
