Thank you so much.. It works fine. But there is something that occurs when I change it. According to the quick example that is Eric Norum's under this talk, 1) I make an IOC example with "../../../makeBaseApp -t example example" "../../../makeBaseApp -i -t example example" I've got the same result as the same with Eric Norum's. 2) I run it. Again,I've got the same result. I mean that works fine. 3) But after you said that edit the PATH , I did this. "export PATH=/opt/epics/base/bin/linux-x86_64" And camonitor does not work in other terminal. If I edit it again on the current terminal, it works fine. But under that terminal , when I try to do 4th step, which is runnig the Octave, there is an error that's saying it's a different path with Octave. I am wondering, did I make a wrong building for Epics_Base at the beginning by setting the environment variables. Or is there another way to do it permanently for just Epics_Base path, for not the others (since I've got path error on the same terminal while I have to run different apps.).When I edit it, the others (such as Octave) are changing in terms of PATH. Thanks in advance.. Best Regards.. 2016-07-23 0:38 GMT+03:00 Mark Rivers <[email protected]>:
| ANJ, 22 Jul 2016 |
Home
News
About
Talk
Base
Modules
Extensions
