1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to configurate MCA for Octave
To: Hulusi Öz <[email protected]>
Cc: EPICS tech talk <[email protected]>
Date: Fri, 22 Jul 2016 15:04:23 -0700
You need to read up on Linux shell operation.
The PATH environment variable should contain a colon-separated lists of directories in which the shell will look for executables.
On Jul 22, 2016, at 3:01 PM, Hulusi Öz <[email protected]> wrote:
3) But after you said that edit the PATH , I did this. "export PATH=/opt/epics/base/bin/linux-x86_64"
    And camonitor does not work in other terminal. If I edit it again on the current terminal, it works fine.
    But under that terminal , when I try to do 4th step, which is runnig the Octave, there is an error that's saying it's a different path with Octave.
Eric Norum
[email protected]
How to configurate MCA for Octave Hulusi Öz
Re: How to configurate MCA for Octave Eric Norum
Re: How to configurate MCA for Octave Hulusi Öz
RE: How to configurate MCA for Octave Mark Rivers
Prev: Re: How to configurate MCA for Octave Hulusi Öz
Next: Re: How to configurate MCA for Octave Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 22 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
