1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: NDDataType change
To: "'Hinxx'" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 7 Oct 2016 14:54:50 +0000
Is this in a running IOC?  If so there is probably an EPICS record that controls the data type.  That record could define the value in the database file, or it could be restored from autosave?
From: [email protected] [mailto:[email protected]] On Behalf Of Hinxx
Sent: Friday, October 07, 2016 9:20 AM
To: EPICS Tech-Talk
Subject: NDDataType change
I'm extending asynNDArrayDriver and setting the NDDataType parameter to NDInt16 (enum 2) in constructor of my class (I can see this is happening in the gdb).
When I get into acquireArrays() (copy paste from ADCSimulator ADExample code) the NDDataType parameter is for some reason NDUInt16 (enum 3).
Why would that happen? My code is not touching the NDDataType parameter anywhere else than in constructor.
Hinko
Re: NDDataType change Hinko Kocevar
NDDataType change Hinxx
Prev: NDDataType change Hinxx
Next: Re: StreamDevice fails to compile for RTEMS targets. Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: NDDataType change Hinko Kocevar
ANJ, 07 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
