1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice fails to compile for RTEMS targets.
To: <[email protected]>
Date: Fri, 7 Oct 2016 10:30:50 -0500
Hi Mike,
On 10/07/2016 08:04 AM, Michael Westfall wrote:
> What were able to finally figure out is that -- for RTEMS targets,
> anyway -- The order of PROD_LIBS += xxx matters. For example, to
> resolve the errors above, I moved the line PROD_LIBS += seq pv to
> below the lines that included the CALC and SSCAN libraries.
I'm slightly surprised that the VxWorks builds that I know synapps is
tested on didn't discover this issue.
> It must be that there is something different about how the linker in the
> RTEMS toolchain works that isn't a problem in the linker for Linux.
Actually the Linux linker would see exactly the same problem if the
build were configured to link with the static libraries instead of the
shared ones, but very few people build static executables on Linux
nowadays. Builds for VxWorks and RTEMS that generate loadable binaries
are normally linked statically since those OSs don't support shared
libraries.
Static linking normally happens in a single pass, so the linker goes
through each library in turn, searching for symbols that are needed and
adding any object files from that library that contain undefined symbols
to the output file. If a library added later turns out to need a file
from an earlier library that wasn't known to be needed when that library
was linked, the result is going to be an unresolved symbol and a build
failure.
If you're linking against shared libraries though, the final resolving
of undefined symbols doesn't happen until run-time, when all the object
files in each shared library get mapped into the executable anyway so
all library symbols then become available.
If you are using RTEMS with GeSYS then the situation is a bit more like
using shared libraries (or the old 3.13 VxWorks approach) because the
whole library gets loaded into memory. GeSYS has advantages as well as
disadvantages, but it does require more RAM in the target to hold the
symbol table. I don't believe synapps is currently set up to work with
GeSYS (but I may be wrong about that).
HTH,
- Andrew
RE: StreamDevice fails to compile for RTEMS targets. Mooney, Tim M.
StreamDevice fails to compile for RTEMS targets. Michael Westfall
RE: StreamDevice fails to compile for RTEMS targets. Mark Rivers
Fwd: StreamDevice fails to compile for RTEMS targets. Michael Westfall
Re: StreamDevice fails to compile for RTEMS targets. Michael Westfall
Prev: RE: NDDataType change Mark Rivers
Next: Re: NDDataType change Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice fails to compile for RTEMS targets. Michael Westfall
Next: RE: StreamDevice fails to compile for RTEMS targets. Mooney, Tim M.
ANJ, 07 Oct 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
