1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: FLOOR function in EPICS CALC error
To: <[email protected]>
Cc: [email protected]
Date: Mon, 14 Nov 2016 10:45:49 +0000
Thank you Mark and Tim,
I understand what is happening now, I should have checked the precision set on PREC to see this correctly. With the correct PREC, I see the irrational part now.
Thank you for your time,
Rory
From: Engbretson, Mark S. [mailto:[email protected]]
Sent: 11 November 2016 20:24
To: Clarke, Rory (STFC,DL,TECH)
Subject: Re: FLOOR function in EPICS CALC error
I.e. 0.01 is a endlessly ongoing bit string in base 2. The number can not be represented without lose on a binary computer.
On Nov 11, 2016, at 14:19, Engbretson, Mark S. <[email protected]> wrote:
Wouldn't an easier test of FLOOR be just to use the floor statement with a constant? If it was really broken, order of parens should make little different. since it does, it seems as if the actual value of the calculation is suffering from a precision issue.
On Nov 11, 2016, at 14:08, <[email protected]> <[email protected]> wrote:
I am seeing what I think may be a rounding error in the FLOOR function and I was wondering if others had seen this. I replaced the variables in my code with actual values to reproduce the problem. I am using EPICS R3.14.12.5 with Scientific Linux 7. I also tried it with the same version of EPICS running on Linux Mint
In Calc records, just using an empty Calc record and putting the values in by hand:
record(calc,"DLY:FSTEP")
 field(CALC,"6.1-0.2/0.01")
6.1-0.2/0.01 gives 590 as it should
However:
FLOOR((6.1-0.2)/0.01)
Gives me 589
If I write it as follows:
FLOOR((6.1-0.2)*(1/0.01))
I again get 590 (as it should be)
I wondered if this was my install or if this has been seen before. It only seems to happen for random values.
Best regards,
Rory Clarke
FLOOR function in EPICS CALC error rory.clarke
Prev: mutex lock assertion failure Christian Pulvermacher
Next: RE: mutex lock assertion failure Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: FLOOR function in EPICS CALC error Mooney, Tim M.
Next: Modbus Device Support for Advantech ADAM6017, 6018 David Vine
ANJ, 14 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
