1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: OS X edm/medm openmotif woes
To: "J. Lewis Muir" <[email protected]>
Cc: Eric Norum <[email protected]>, tech-talk <[email protected]>
Date: Mon, 14 Nov 2016 16:46:19 -0600
Hi Lewis,
Actually, Eric and I got this sorted out a while ago, but I guess never posted the solutions on the Tech-Talk.
The trick was to install the new version of XQuartz (2.7.10_rc5 or newer should do), then, set DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace.  That solved the problem for Eric and me.
> On Nov 14, 2016, at 4:41 PM, J. Lewis Muir <[email protected]> wrote:
> On 08/26, Jiro Fujita wrote:
>> Hi Eric,
>> I was about to let you know sort of a bad news.  I found nothing interesting on my old computer, so I decided to try installing MEDM on one of my lab iMacs.  Well, unfortunately, I get the same problem as you do.  So clearly, back in November/December, I must have made some small adjustment somewhere to get MEDM working on El Capitan with OpenMotif.
>> I will play with it more and let you know, once I have something…
> I upgraded and rebuilt some things, and MEDM crashes for me too now. :-(
> Did you ever figure anything out?
> I'm on macOS Sierra (10.12.1) with Motif 2.3.4 ([1]), MEDM 3.1.9, and
> XQuartz 2.7.10.  I see that there's a Motif 2.3.6 and an XQuartz 2.7.11,
> so I'll probably try upgrading those before anything else.
> Thanks,
> Lewis
> [1] https://sourceforge.net/projects/motif/
Re: OS X edm/medm openmotif woes J. Lewis Muir
OS X edm/medm openmotif woes Eric Norum
Re: OS X edm/medm openmotif woes Jiro Fujita
Re: OS X edm/medm openmotif woes Eric Norum
Prev: Re: OS X edm/medm openmotif woes J. Lewis Muir
Next: RE: mutex lock assertion failure Christian Pulvermacher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: OS X edm/medm openmotif woes J. Lewis Muir
ANJ, 15 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
