On 11/14, Jiro Fujita wrote:
> Hi Lewis,
> Actually, Eric and I got this sorted out a while ago, but I guess
> never posted the solutions on the Tech-Talk.
> The trick was to install the new version of
> XQuartz (2.7.10_rc5 or newer should do), then, set
> DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace. That solved the
> problem for Eric and me.
Thanks!
For anyone else following this, the problem appears to be that the
libXt dynamic library as provided by XQuartz 2.7.10 and newer is now a
two-level-namespace dynamic library. Motif 2.3.4 will only work with
a flat-namespace libXt dynamic library, so things are broken.
XQuartz 2.7.9 also introduced a related change to libXt, but I don't
know if it breaks things. The XQuartz 2.7.9 release notes are at:
https://www.xquartz.org/releases/XQuartz-2.7.9.html
They include this note:
libXt
* No longer linked with -flat_namespace
* Binary compatibility maintained for existing clients of libXt.6.dylib
Anyway, I upgraded to XQuartz 2.7.11 and, as expected, still had the
problem with medm crashing immediately.
The XQuartz project says Motif is broken and encourages users to file
a bug report against the Motif project. Info about this and the
DYLD_LIBRARY_PATH workaround can be found in the XQuartz 2.7.10 release
notes:
https://www.xquartz.org/releases/XQuartz-2.7.10.html
What the release notes do not warn about, though, is that the
DYLD_LIBRARY_PATH environment variable (and others) receives special
treatment on macOS due to System Integrity Protection (SIP) which was
added in OS X El Capitan (10.11). I was exec'ing medm from a shell
script and couldn't get the DYLD_LIBRARY_PATH workaround to work because
I did:
$ export DYLD_LIBRARY_PATH=/opt/X11/lib/flat_namespace
$ ./medm-control.sh
In the above case, the DYLD_LIBRARY_PATH environment variable is *not*
passed into the environment of the medm-control.sh shell script because
the shebang is /bin/sh, and /bin/sh is a protected process in SIP!
DYLD_LIBRARY_PATH is set in the shell, but it doesn't get passed into
the environment of protected child processes. /bin/sh is considered
protected:
$ [ $DYLD_LIBRARY_PATH ] || echo nope
$ /bin/sh -c '[ $DYLD_LIBRARY_PATH ] || echo nope'
nope
This drove me crazy trying to figure out what was going on! Once I set
and exported DYLD_LIBRARY_PATH *in* the shell script before exec'ing
medm, then it worked!
This behavior is explained in the Runtime Protections section ([1]) of
the System Integrity Protection Guide:
Spawning children processes of processes restricted by System
Integrity Protection, such as by launching a helper process in a
bundle with NSTask or calling the exec(2) command, resets the Mach
special ports of that child process. Any dynamic linker (dyld)
environment variables, such as DYLD_LIBRARY_PATH, are purged when
launching protected processes.
Long term, Motif needs to be fixed to work with a two-level-namespace
libXt. In the short term, though, the above workaround worked for me.
Another workaround I tried that worked and did not require setting
the DYLD_LIBRARY_PATH environment variable was to move the
two-level-namespace libXt dynamic library from XQuartz out of the way
and replace it with the flat-namespace version XQuartz provides:
$ cd /opt/X11/lib
$ sudo mv libXt.6.dylib libXt.6.dylib.orig
$ sudo ln -s flat_namespace/libXt.6.dylib
I don't know if that's a reasonable hack if setting the
DYLD_LIBRARY_PATH environment variable is not an option, but it worked
for me for medm.
Another option, that I did not try but that I think would work, is to
downgrade XQuartz to 2.7.8.
Lewis
[1] https://developer.apple.com/library/content/documentation/Security/Conceptual/System_Integrity_Protection_Guide/RuntimeProtections/RuntimeProtections.html
- Re: OS X edm/medm openmotif woes Pete Jemian
- Re: OS X edm/medm openmotif woes Matt Newville
- OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes Jiro Fujita
- Re: OS X edm/medm openmotif woes Eric Norum
- Re: OS X edm/medm openmotif woes J. Lewis Muir
Re: module for Keithley 6485 PA-meter Márcio Paduan Donadio
RE: module for Keithley 6485 PA-meter Mark Rivers
<2016>
2025
2026
<2016>
2025
2026
