Hi Paramveer,
I have a couple of suggestions.
- You appear to be running asyn R4-18. That release is 5 years old, and there have been a number of bug fixes and enhancements since then. Is it possible for you to upgrade?
- The HowToDoSerial tutorial you are using is for an obsolete method of talking to devices using the devGpib device support. There are very few people who use that anymore who would be able to help you. The recommended replacement is StreamDevice, and there is a new tutorial that shows how to use it with asyn.
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-30/HowToDoSerial/HowToDoSerial_StreamDevice.html
From: [email protected] [[email protected]] on behalf of Paramveer Jain [[email protected]]
Sent: Tuesday, November 15, 2016 12:10 AM
To: [email protected]
Subject: IOC for keithley 6485 using asyn
hello,
I am designing an IOC for Keithley 6485 using IOC
after all steps discussed in
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-3/HowToDoSerial/tutorial.html ,When I run the IOC following is the output --
pxbl21-1@linux-edqv:~/programs/epics/bl21/K6485/iocBoot/iocK6485> ../../bin/linux-x86_64/K6485 st.cmd
#!../../bin/linux-x86_64/K6485
## You may have to change K6485 to something else
## everywhere it appears in this file
epicsEnvSet("BL","bl21:")
epicsEnvSet("P","K6485:")
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocK6485")
epicsEnvSet("TOP","/home/pxbl21-1/programs/epics/bl21/K6485")
epicsEnvSet("K6485","/home/pxbl21-1/programs/epics/bl21/K6485")
epicsEnvSet("ASYN","/home/pxbl21-1/programs/epics/modules/synApps_5_6/support/asyn-4-18")
epicsEnvSet("EPICS_BASE","/home/pxbl21-1/programs/epics/base-3.14.12.5")
cd "/home/pxbl21-1/programs/epics/bl21/K6485"
#dbLoadDatabase "dbd/devK6485.dbd"
dbLoadDatabase "dbd/K6485.dbd"
K6485_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynIPPortConfigure port ipInfo priority noAutoconnect noProcessEos
drvAsynSerialPortConfigure("L0","/dev/ttyUSB0",0,0,0)
asynSetOption("L0", -1, "baud", "57600")
asynSetOption("L0", -1, "bits", "8")
asynSetOption("L0", -1, "parity", "none")
asynSetOption("L0", -1, "stop", "1")
asynSetOption("L0", -1, "crtscts", "N")
asynSetTraceFile("L0",-1,"")
asynSetTraceMask("L0",-1,0x09)
asynSetTraceIOMask("L0",-1,0x2)
## Load record instances
dbLoadRecords("db/devK6485.db","BL=bl21:,P=K6485:,R=1,L=0,A=-1,NELM=1000")
dbLoadRecords ("db/asynRecord.db","P=K6485:,R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=0")
cd "/home/pxbl21-1/programs/epics/bl21/K6485/iocBoot/iocK6485"
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Sep 15 2016
Warning -- devK6485 respond2Writes is set but has no command table entry with rspLen>0.
bl21:K6485:1AutozeroRBV : init_record : record type invalid for spec'd GPIB param#11
bl21:K6485:1DisplayRBV : init_record : record type invalid for spec'd GPIB param#15
bl21:K6485:1ZeroCheckRBV : init_record : record type invalid for spec'd GPIB param#12
bl21:K6485:1ZerocorrectRBV : init_record : record type invalid for spec'd GPIB param#13
bl21:K6485:1Autozero : init_record : record type invalid for spec'd GPIB param#11
bl21:K6485:1Display : init_record : record type invalid for spec'd GPIB param#15
bl21:K6485:1RangeRBV : init_record : record type invalid for spec'd GPIB param#10
## Start any sequence programs
#seq sncxxx,"user=pxbl21-1Host"
epics>
please have a look on highlighted lines, I am unable to understand What does they mean. I hope someone to help me to get some idea.
Thanks in advance
With Regards,
Paramveer Jain
- IOC for keithley 6485 using asyn Paramveer Jain
Re: module for Keithley 6485 PA-meter Paramveer Jain
Re: module for Keithley 6485 PA-meter Márcio Paduan Donadio
<2016>
2025
2026
Philosophy regarding use of open source libraries for EPICS Rod Nussbaumer
<2016>
2025
2026
