1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS/RTEMS Compilation errors
To: <[email protected]>
Date: Mon, 28 Nov 2016 18:19:22 +0100
On 28.11.2016 18:06, Michael Davidsaver wrote:
> On 11/28/2016 11:54 AM, Benjamin Franksen wrote:
>> On 28.11.2016 15:49, Jianxun Yan wrote:
>> Not sure but
>>   ".../librtemscpu.a uses VFP register arguments, libComTestHarness does
>> not"
>> sounds a lot like a mismatch of compiler or linker flags between the BSP
>> and EPICS.
>> Also my first guess for what "VFP" means would be "virtual floating
>> point" i.e. use FP emulation instead of a 'real' FP unit.
> VFP = Vector Floating Point aka. hard float.
> https://www.arm.com/products/processors/technologies/vector-floating-point.php
> The linker is catching an otherwise hard to detect condition where
> different object files are compiled with different function calling
> conventions (ABI).  In this case whether function arguments are pass in
> VFP registers.
> The relevant GCC option is '-mfloat-abi=soft|softfp|hard'.  I would
> guess that different values were given when building the RTEMS libraries
> vs. EPICS Base.
> https://gcc.gnu.org/onlinedocs/gcc-4.9.3/gcc/ARM-Options.html#ARM-Options
Thanks for correcting my half-baked guesses. At least I was right that
it has to do with a compiler flag mismatch... ;-)
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS/RTEMS Compilation errors Jianxun Yan
Re: EPICS/RTEMS Compilation errors Benjamin Franksen
Re: EPICS/RTEMS Compilation errors Michael Davidsaver
Prev: Re: Asyn daemon + console + log Benjamin Franksen
Next: Re: Asyn daemon + console + log Keith Thorne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS/RTEMS Compilation errors Michael Davidsaver
Next: Re: EPICS/RTEMS Compilation errors Jianxun Yan
ANJ, 28 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
