1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS/RTEMS Compilation errors
To: Benjamin Franksen <[email protected]>, [email protected]
Date: Mon, 28 Nov 2016 12:06:48 -0500
On 11/28/2016 11:54 AM, Benjamin Franksen wrote:
> On 28.11.2016 15:49, Jianxun Yan wrote:
> Not sure but
>   ".../librtemscpu.a uses VFP register arguments, libComTestHarness does
> not"
> sounds a lot like a mismatch of compiler or linker flags between the BSP
> and EPICS.
> Also my first guess for what "VFP" means would be "virtual floating
> point" i.e. use FP emulation instead of a 'real' FP unit.
VFP = Vector Floating Point aka. hard float.
https://www.arm.com/products/processors/technologies/vector-floating-point.php
The linker is catching an otherwise hard to detect condition where
different object files are compiled with different function calling
conventions (ABI).  In this case whether function arguments are pass in
VFP registers.
The relevant GCC option is '-mfloat-abi=soft|softfp|hard'.  I would
guess that different values were given when building the RTEMS libraries
vs. EPICS Base.
https://gcc.gnu.org/onlinedocs/gcc-4.9.3/gcc/ARM-Options.html#ARM-Options
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS/RTEMS Compilation errors Benjamin Franksen
EPICS/RTEMS Compilation errors Jianxun Yan
Prev: Re: Channel Archiver - Data Conversion / Export from File to RDBArchiver PostgreSQL database Kasemir, Kay
Next: Re: Asyn daemon + console + log Benoit Rat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS/RTEMS Compilation errors Benjamin Franksen
Next: Re: EPICS/RTEMS Compilation errors Benjamin Franksen
ANJ, 28 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
