> Are you sure that your CentOS 7 box exports the file system also as NFS 2?
That is probably the problem. Do you know how to enable that?
Sent: Thursday, January 19, 2017 7:08 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
Hi Mark,
You do recall that VxWorks 5.5 only has an NFS 2 implementation, right?
(See http://www.vxdev.com/docs/vx55man/vxworks/netguide/c-remAccApps.html#87831)
Cheers,
~Ralph
On Thu, Jan 19, 2017 at 1:51 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
> But one observation I made is that Centos 7 uses NFS 4.
> To my understanding NFS 4 does not map the numerical user/group id
> "1:1", by default, but wants to translate the remote user id into a local one in some way.
> And this is a security improvement.
> Can you mount Centos 7 -> Centos 7 ?
Yes, we have successfully NFS mounted Centos 7 file systems from the following systems:
Centos 7
RHEL 6
Fedora 9
Fedora 15
Fedora 23
vxWorks 6.9.4
The only one that does not seem to work is vxWorks 5.5.
Han wrote:
> Do you enable firewall service?
No, firewalld is not running.
From: Torsten Bögershausen [[email protected]<mailto:[email protected]>]
Sent: Thursday, January 19, 2017 12:37 AM
To: Mark Rivers; [email protected]<mailto:[email protected]>
>Is anyone running vxWorks 5.5 with a Centos 7/ RHEL 7, etc. modern NFS server?
Not me.
in some way.
In short: We needed to tweak a file called /etc/idmapd.conf.
I can dig out the details later.
On 19/01/17 02:00, Mark Rivers wrote:
> Folks,
> We are mostly running VxWorks 6.9.4 now, and with that we have no problem NFS
> mounting file systems on Centos 7.
> However, we have a few IOCs that still need to run VxWorks 5.5. These can
> mount file systems on Centos 5 servers fine. However, on Centos 7 we see the
> following:
> - The NFS mount command from vxWorks succeeds with no error
> - showmount on the Centos 7 system shows that the vxWorks system has
> mounted the file system OK
> - However, the vxWorks system cannot actually read or write any files
> on the file system.
> If I type the “ls” command in a valid directory I get
> Cant’ open “null”.
> Value=-1
> The problem is not file permissions, it works fine if we are running the
> identical IOC with vxWorks 6.9.4, and we have tried setting the files in that
> directory to mode 755.
> If so, how does one get it to work?
> Thanks,
> Mark
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jörn Dreyer
Re: Problem compiling StreamDevice on Visual Studio 2015 Dirk Zimoch
<2017>
2025
<2017>
2025
