Subject: |
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 |
Jörn Dreyer <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 19 Jan 2017 14:16:12 +0100 |
Hi Mark,
I had a similar problem mounting a NFS share from a debian server onto a
LynxOS system with NFS4 and NFS3 enabled on the server but the client only
capable of NFS2.
I had to switch off NFS4 and enable NFS2 on the server to get the mount
working. Enabling only NFS2 and leaving NFS4 running, it would not work. It
seems that NFS4 will not fallback to other versions if the client does not
connect with NFS4.
Hope that helps a bit,
Jörn
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
<2017>
2025
NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) Andrew Johnson
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jeong Han Lee
<2017>
2025
