Subject: |
NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) |
Andrew Johnson <[email protected]> |
To: |
Date: |
Fri, 20 Jan 2017 16:05:27 -0600 |
If anyone in the EPICS RTEMS community gets this NFSv3 client working,
please report that here and explain which RTEMS version(s) it works on...
- Andrew
On 01/20/2017 04:30 AM, Heinz Junkes wrote:
> Found this in RTEMS-Maillist:
> Message: 1
> Date: Mon, 13 Jun 2016 14:33:23 +0200
> <http://airmail.calendar/2016-06-13%2014:33:23%20GMT+2>
> From: Sebastian Huber <[email protected]
> <mailto:[email protected]>>
> To: Till Straumann <[email protected]
> <mailto:[email protected]>>, RTEMS
> <[email protected] <mailto:[email protected]>>
> Subject: Re: Standard RTEMS NFSv3 client now available via libbsd
> Message-ID: <[email protected]
> Content-Type: text/plain; charset=utf-8; format=flowed
> On 10/06/16 16:47
> <http://airmail.calendar/2016-06-10%2016:47:00%20GMT+2>, Till Straumann
> wrote:
>> The client is V2, not V3.
> Thanks for clarification, this explains why its necessary to enable a
> legacy mode on one NFS server to be able to work with RTEMS clients.
>> We have a low-priority project to add V3 but having a low priority I'm
>> not sure if or when it's going to happen...
> Another option would be to port the FreeBSD NFS client to RTEMS. For
> this we need a FreeBSD kernel file system layer to RTEMS file system
> layer adaptor.
>> - Till
>> On 06/10/2016 05:20 AM
> <http://airmail.calendar/2016-10-06%2005:20:00%20GMT+2>, Sebastian Huber
> wrote:
>>> Hello,
>>> I imported a snapshot of the standard RTEMS NFSv3 client from Till
>>> Straumann to the libbsd (the new network stack). The RPC deamon uses
>>> a kqueue() instead of RTEMS events for synchronization. The zero-copy
>>> optimization by means of direct usage of mbufs is currently not
>>> available due to a lack of time and budget.
> Sebastian Huber, embedded brains GmbH
> Heinz
> On 19 January 2017 at 18:37:37, Andrew Johnson ([email protected]
> <mailto:[email protected]>) wrote:
>> Calling all RTEMS developers (Till, Eric, Michael, Heinz): Given the
>> statement below from Red Hat, are there any plans in the works to
>> support NFSv3 or later on RTEMS, or some other modern network filesystem
>> protocol?
>> On 01/19/2017 10:42 AM, Torsten Bögershausen wrote:
>> > But I am afraid that NFS 2 is no longer supported:
>> > <https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html-single/Storage_Administration_Guide/index.html#ch-nfs>
>> The RTEMS NFSv2 client does talk to our RHEL-7.3 server with the
>> configuration change I posted for Mark, but the VxWorks 5.4.2 NFS client
>> broke somewhere between the RHEL-7.2 and 7.3 servers. VxWorks 5.5 has an
>> NFSv3 client (which is buggy, make sure you get all the available
>> patches) that works OK against a RHEL-7.3 server.
>> The APS now only has *2* production IOCs left running on EPICS 3.13.10,
>> having upgraded the others to Base-3.14.12 and VxWorks 5.5 or 6.9. This
>> solved the NFSv2 issue for VxWorks, but our RTEMS-4.9.2 and 4.10.2
>> systems are still stuck with NFSv2...
>> - Andrew
>> Arguing for surveillance because you have nothing to hide is no
>> different than making the claim, "I don't care about freedom of
>> speech because I have nothing to say." -- Edward Snowdon
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
- Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Heinz Junkes
Re: Emulating the use of Global VxWorks Variables in OSI Andrew Johnson
Re: Emulating the use of Global VxWorks Variables in OSI Matt Rippa
<2017>
2025
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jörn Dreyer
<2017>
2025
