1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 20 Jan 2017 11:30:51 +0100
Found this in RTEMS-Maillist:
Message: 1
Date: Mon, 13 Jun 2016 14:33:23 +0200
To: Till Straumann <[email protected]>, RTEMS
<[email protected]
Subject: Re: Standard RTEMS NFSv3 client now available via libbsd
Message-ID: <[email protected]
Content-Type: text/plain; charset=utf-8; format=flowed
On 10/06/16 16:47, Till Straumann wrote:
> The client is V2, not V3.
Thanks for clarification, this explains why its necessary to enable a
legacy mode on one NFS server to be able to work with RTEMS clients.
> We have a low-priority project to add V3 but having a low priority I'm
> not sure if or when it's going to happen...
Another option would be to port the FreeBSD NFS client to RTEMS. For
this we need a FreeBSD kernel file system layer to RTEMS file system
layer adaptor.
> - Till
On 06/10/2016 05:20 AM, Sebastian Huber wrote:
>> Hello,
>> I imported a snapshot of the standard RTEMS NFSv3 client from Till
>> Straumann to the libbsd (the new network stack). The RPC deamon uses
>> a kqueue() instead of RTEMS events for synchronization. The zero-copy
>> optimization by means of direct usage of mbufs is currently not
>> available due to a lack of time and budget.
Sebastian Huber, embedded brains GmbH
Heinz
On 19 January 2017 at 18:37:37, Andrew Johnson ([email protected]) wrote:
Calling all RTEMS developers (Till, Eric, Michael, Heinz): Given the
statement below from Red Hat, are there any plans in the works to
support NFSv3 or later on RTEMS, or some other modern network filesystem
protocol?
On 01/19/2017 10:42 AM, Torsten Bögershausen wrote:
> But I am afraid that NFS 2 is no longer supported:
> <https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html-single/Storage_Administration_Guide/index.html#ch-nfs>
The RTEMS NFSv2 client does talk to our RHEL-7.3 server with the
configuration change I posted for Mark, but the VxWorks 5.4.2 NFS client
broke somewhere between the RHEL-7.2 and 7.3 servers. VxWorks 5.5 has an
NFSv3 client (which is buggy, make sure you get all the available
patches) that works OK against a RHEL-7.3 server.
The APS now only has *2* production IOCs left running on EPICS 3.13.10,
having upgraded the others to Base-3.14.12 and VxWorks 5.5 or 6.9. This
solved the NFSv2 issue for VxWorks, but our RTEMS-4.9.2 and 4.10.2
systems are still stuck with NFSv2...
- Andrew
Attachment: smime.p7s
Description: S/MIME cryptographic signature
NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) Andrew Johnson
Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
Prev: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Next: Table properties in CSS BOY Shantonu Sahoo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Next: NFSv3 Client for RTEMS (was: Problem NFS mounting Centos 7 file systems from vxWorks 5.5) Andrew Johnson
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
