1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
Date: Tue, 24 Jan 2017 17:01:36 +0000
Folks,
This is a follow-up with the resolution to this problem.
The problem was resolved by fixing the Analogic DVX-2503 driver (drvDvx.c) so that it no longer generates interrupt errors on the MVME2100 with vxWorks 6.9.4.  Andrew fixed the problem, which was the need for a final read operation at the end of the Interrupt Service Routine.  So we no longer have a need for VxWorks 5.5, and hence no need to support NFSv2 on Centos 7.
Thanks Andrew!
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Thursday, January 19, 2017 12:01 PM
To: 'Andrew Johnson'; [email protected]
Hi Andrew,
Good news and bad news.
The good news is that by booting vx55 with -asd8 I can mount NFS on our Centos7 server without changing its NFS configuration.
The bad news is that by changing from -asd7 to -asd8 we introduce the uninitialized interrupt messages from our Analogic DVX-2503 cards.
These messages do not happen on:
MVME5100 with VxWorks 5.5 or 6.9.4
MVME2100 with VxWorks 5.5 -asd7
They do occur with:
MVME2100 with VxWorks 6.9.4 or 5.5 -asd8.
Is anyone else using Analogic DVX-2503 cards with VxWorks?  If so, what version of VxWorks?
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Thursday, January 19, 2017 11:36 AM
To: [email protected]
Subject: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5
Calling all RTEMS developers (Till, Eric, Michael, Heinz): Given the
statement below from Red Hat, are there any plans in the works to
support NFSv3 or later on RTEMS, or some other modern network filesystem
protocol?
On 01/19/2017 10:42 AM, Torsten Bögershausen wrote:
> But I am afraid that NFS 2 is no longer supported:
> <https://access.redhat.com/documentation/en-US/Red_Hat_Enterprise_Linux/7/html-single/Storage_Administration_Guide/index.html#ch-nfs>
The RTEMS NFSv2 client does talk to our RHEL-7.3 server with the
configuration change I posted for Mark, but the VxWorks 5.4.2 NFS client
broke somewhere between the RHEL-7.2 and 7.3 servers. VxWorks 5.5 has an
NFSv3 client (which is buggy, make sure you get all the available
patches) that works OK against a RHEL-7.3 server.
The APS now only has *2* production IOCs left running on EPICS 3.13.10,
having upgraded the others to Base-3.14.12 and VxWorks 5.5 or 6.9. This
solved the NFSv2 issue for VxWorks, but our RTEMS-4.9.2 and 4.10.2
systems are still stuck with NFSv2...
- Andrew
Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Ralph Lange
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
Prev: Re: Query related to channel access address list setting Ralph Lange
Next: Question about EDM Problems lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
Next: Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Heinz Junkes
ANJ, 21 Dec 2017 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
