Subject: RE: problem connecting serial device with moxa 5150A
To: haquin <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Jan 2017 14:40:14 +0000
It is definitely port 4001 for this Moxa using TCP server mode.  The attached screen shot from the Moxa shows this, and telnet from Windows to that port connects fine.
It uses port 966 as the Command Port, but 4001 for the data.
4001 is also what I use for the Moxas on our beamlines:
corvette:~/devel/CARS/iocBoot>find . -name '*.cmd' -exec grep -H 4001 {} \;
./ioc13GasLoading/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.163:4001", 0, 0, 0)
./ioc13Win32/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.50:4001", 0, 0)
./ioc13laser/st.cmd:drvAsynIPPortConfigure("serial1", "gsets3:4001", 0, 0)
./iocCARSPil3Table/st.cmd:drvAsynIPPortConfigure("serial1", "pil3-mcb4b:4001", 0, 0)
./ioc13bmc_laser/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.53:4001", 0, 0, 0)
./ioc13bmd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.36:4001")
./ioc13idd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.30:4001")
./ioc13lab/serial.cmd:#drvAsynIPPortConfigure("serial20", "164.54.160.50:4001", 0, 0)
From: [email protected] [[email protected]] on behalf of haquin [[email protected]]
Sent: Tuesday, January 24, 2017 8:23 AM
To: [email protected]
Subject: Re: problem connecting serial device with moxa 5150A
To me port 4001 is not correct, as I said in my previous post,
I use a Moxa 5150 on port 950 not 4001 and it works fine ...
see port list here 4001 is not in ...
http://www.moxa.com/support/faq/faq_detail.aspx?id=646
I've tried port 23 it works fine, 4001 doesn't work
hope it helps
br
Le 24/01/2017 à 15:09, Luca Cavalli a écrit :
> Hi Mark,
> is the routing table correctly configured?
> Cheers,
> Luca
> On Tue, 2017-01-24 at 13:33 +0000, Mark Rivers wrote:
>> I'm trying to help Sunny to connect from Linux to a serial port on a Moxa
>> box.  It is not working, and I am stumped, so any ideas are welcome.
>>  From Windows he can telnet to it:
>>> when I telnet from windows
>>> telnet 192.168.127.254 4001
>>> It prompts a blank screen and for other IP or ports like 192.168.127.254
>>> 5064, 192.168.127.34 4732 etc. it simply says host not available so I think
>>> port 4001 should be good.
>> When he connects it to Linux he can ping it:
>> ping 192.168.127.254
>> PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255
>> time=1.69 ms
>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255
>> time=0.797 ms
>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255
>> time=0.753 ms
>> ifconfig looks OK:
>> eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
>>            inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
>>            inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
>>            UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
>>            RX packets:16 errors:0 dropped:0 overruns:0 frame:0
>>            TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
>>            collisions:0 txqueuelen:1000
>>            RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
>> arp looks good:
>> sbin/arp
>> Address                  HWtype  HWaddress           Flags
>> Mask            Iface
>> 10.128.0.254             ether   00:00:5e:00:01:83   C                     eth
>> 1
>> 10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth
>> 1
>> 10.128.0.253             ether   00:04:96:15:5e:70   C                     eth
>> 1
>> 10.128.0.238             ether   00:04:96:27:50:63   C                     eth
>> 1
>> 10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth
>> 1
>> 10.128.0.252             ether   00:04:96:28:24:ce   C                     eth
>> 1
>> 10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth
>> 1
>> 192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth
>> 0
>> 10.128.0.251             ether   00:04:96:16:c7:50   C                     eth
>> 1
>> 10.128.0.249             ether   00:04:96:05:7a:13   C                     eth
>> 1
>> 10.128.0.247             ether   00:04:96:36:54:da   C                     eth
>> 1
>> 10.128.0.246             ether   00:04:96:21:d6:10   C                     eth
>> 1
>> The firewall is disabled:
>>   systemctl status SuSEfirewall2.service
>> SuSEfirewall2 phase 2
>>     Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
>>     Active: inactive (dead)
>> But when he tries to telnet from the Linux box it times out:
>> Trying 192.168.127.254...
>> telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection
>> timed out
>> Any ideas what could be causing this?
>> Thanks,
>> Mark
> << Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
> << This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
Attachment: 4 (1).PNG
Description: 4 (1).PNG
Re: problem connecting serial device with moxa 5150A Martin L. Smith
problem connecting serial device with moxa 5150A Sunny Badkul
RE: problem connecting serial device with moxa 5150A Mark Rivers
Re: problem connecting serial device with moxa 5150A Luca Cavalli
Re: problem connecting serial device with moxa 5150A haquin
Prev: Re: problem connecting serial device with moxa 5150A haquin
Next: RE: problem connecting serial device with moxa 5150A freddie.akeroyd
Next: Re: problem connecting serial device with moxa 5150A Martin L. Smith
