1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem connecting serial device with moxa 5150A
To: Mark Rivers <[email protected]>, haquin <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 24 Jan 2017 10:03:26 -0600
Mark,
Check that the moxa box has the correct netmask set, I have seen similar
problems with incorrectly configured moxa network settings.
Marty
On 01/24/2017 08:40 AM, Mark Rivers wrote:
It is definitely port 4001 for this Moxa using TCP server mode.  The attached screen shot from the Moxa shows this, and telnet from Windows to that port connects fine.
It uses port 966 as the Command Port, but 4001 for the data.
4001 is also what I use for the Moxas on our beamlines:
corvette:~/devel/CARS/iocBoot>find . -name '*.cmd' -exec grep -H 4001 {} \;
./ioc13GasLoading/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.163:4001", 0, 0, 0)
./ioc13Win32/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.50:4001", 0, 0)
./ioc13laser/st.cmd:drvAsynIPPortConfigure("serial1", "gsets3:4001", 0, 0)
./iocCARSPil3Table/st.cmd:drvAsynIPPortConfigure("serial1", "pil3-mcb4b:4001", 0, 0)
./ioc13bmc_laser/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.53:4001", 0, 0, 0)
./ioc13bmd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.36:4001")
./ioc13idd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.30:4001")
./ioc13lab/serial.cmd:#drvAsynIPPortConfigure("serial20", "164.54.160.50:4001", 0, 0)
From: [email protected] [[email protected]] on behalf of haquin [[email protected]]
Sent: Tuesday, January 24, 2017 8:23 AM
To: [email protected]
To me port 4001 is not correct, as I said in my previous post,
I use a Moxa 5150 on port 950 not 4001 and it works fine ...
see port list here 4001 is not in ...
http://www.moxa.com/support/faq/faq_detail.aspx?id=646
I've tried port 23 it works fine, 4001 doesn't work
hope it helps
br
Le 24/01/2017 à 15:09, Luca Cavalli a écrit :
Hi Mark,
is the routing table correctly configured?
Cheers,
Luca
On Tue, 2017-01-24 at 13:33 +0000, Mark Rivers wrote:
I'm trying to help Sunny to connect from Linux to a serial port on a Moxa
box.  It is not working, and I am stumped, so any ideas are welcome.
 From Windows he can telnet to it:
when I telnet from windows
telnet 192.168.127.254 4001
It prompts a blank screen and for other IP or ports like 192.168.127.254
5064, 192.168.127.34 4732 etc. it simply says host not available so I think
port 4001 should be good.
When he connects it to Linux he can ping it:
ping 192.168.127.254
PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255
time=1.69 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255
time=0.797 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255
time=0.753 ms
ifconfig looks OK:
eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
           inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
           inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
           RX packets:16 errors:0 dropped:0 overruns:0 frame:0
           TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
           collisions:0 txqueuelen:1000
           RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
arp looks good:
sbin/arp
Address                  HWtype  HWaddress           Flags
Mask            Iface
10.128.0.254             ether   00:00:5e:00:01:83   C                     eth
1
10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth
1
10.128.0.253             ether   00:04:96:15:5e:70   C                     eth
1
10.128.0.238             ether   00:04:96:27:50:63   C                     eth
1
10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth
1
10.128.0.252             ether   00:04:96:28:24:ce   C                     eth
1
10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth
1
192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth
0
10.128.0.251             ether   00:04:96:16:c7:50   C                     eth
1
10.128.0.249             ether   00:04:96:05:7a:13   C                     eth
1
10.128.0.247             ether   00:04:96:36:54:da   C                     eth
1
10.128.0.246             ether   00:04:96:21:d6:10   C                     eth
1
The firewall is disabled:
  systemctl status SuSEfirewall2.service
SuSEfirewall2 phase 2
    Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
    Active: inactive (dead)
But when he tries to telnet from the Linux box it times out:
Trying 192.168.127.254...
telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection
timed out
Any ideas what could be causing this?
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Christophe Haquin
Control and Real Time systems Engineer
+33 231454661 office
+33 231454728 fax
SdA/GIM
GANIL
Bd Henri Becquerel BP 55027
14076 CAEN CEDEX5
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
RE: problem connecting serial device with moxa 5150A Mark Rivers
problem connecting serial device with moxa 5150A Sunny Badkul
Re: problem connecting serial device with moxa 5150A Luca Cavalli
Re: problem connecting serial device with moxa 5150A haquin
Prev: Query regarding plc s7 200 smart interface with EPICS Arnab Dasgupta
Next: RE: problem connecting serial device with moxa 5150A Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
