We checked the netmask. Both the Moxa and ifconfig on that port show 255.255.255.0.
-----Original Message-----
Sent: Tuesday, January 24, 2017 10:03 AM
To: Mark Rivers; haquin; [email protected]
Subject: Re: problem connecting serial device with moxa 5150A
Mark,
Check that the moxa box has the correct netmask set, I have seen similar
problems with incorrectly configured moxa network settings.
Marty
On 01/24/2017 08:40 AM, Mark Rivers wrote:
> It is definitely port 4001 for this Moxa using TCP server mode. The attached screen shot from the Moxa shows this, and telnet from Windows to that port connects fine.
> It uses port 966 as the Command Port, but 4001 for the data.
> 4001 is also what I use for the Moxas on our beamlines:
> corvette:~/devel/CARS/iocBoot>find . -name '*.cmd' -exec grep -H 4001 {} \;
> ./ioc13GasLoading/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.163:4001", 0, 0, 0)
> ./ioc13Win32/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.50:4001", 0, 0)
> ./ioc13laser/st.cmd:drvAsynIPPortConfigure("serial1", "gsets3:4001", 0, 0)
> ./iocCARSPil3Table/st.cmd:drvAsynIPPortConfigure("serial1", "pil3-mcb4b:4001", 0, 0)
> ./ioc13bmc_laser/st.cmd:drvAsynIPPortConfigure("serial1", "164.54.160.53:4001", 0, 0, 0)
> ./ioc13bmd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.36:4001")
> ./ioc13idd/serial.cmd:drvAsynIPPortConfigure("serial17", "164.54.160.30:4001")
> ./ioc13lab/serial.cmd:#drvAsynIPPortConfigure("serial20", "164.54.160.50:4001", 0, 0)
> Mark
> From: [email protected] [[email protected]] on behalf of haquin [[email protected]]
> Sent: Tuesday, January 24, 2017 8:23 AM
> To: [email protected]
> To me port 4001 is not correct, as I said in my previous post,
> I use a Moxa 5150 on port 950 not 4001 and it works fine ...
> see port list here 4001 is not in ...
> http://www.moxa.com/support/faq/faq_detail.aspx?id=646
> I've tried port 23 it works fine, 4001 doesn't work
> hope it helps
> br
> Le 24/01/2017 à 15:09, Luca Cavalli a écrit :
>> Hi Mark,
>> is the routing table correctly configured?
>> Cheers,
>> Luca
>> On Tue, 2017-01-24 at 13:33 +0000, Mark Rivers wrote:
>>> I'm trying to help Sunny to connect from Linux to a serial port on a Moxa
>>> box. It is not working, and I am stumped, so any ideas are welcome.
>>> From Windows he can telnet to it:
>>>> when I telnet from windows
>>>> telnet 192.168.127.254 4001
>>>> It prompts a blank screen and for other IP or ports like 192.168.127.254
>>>> 5064, 192.168.127.34 4732 etc. it simply says host not available so I think
>>>> port 4001 should be good.
>>> When he connects it to Linux he can ping it:
>>> ping 192.168.127.254
>>> PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
>>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255
>>> time=1.69 ms
>>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255
>>> time=0.797 ms
>>> 64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255
>>> time=0.753 ms
>>> ifconfig looks OK:
>>> eth0 Link encap:Ethernet HWaddr D8:CB:8A:9C:61:96
>>> inet addr:192.168.127.0 Bcast:192.168.127.255 Mask:255.255.255.0
>>> inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
>>> UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
>>> RX packets:16 errors:0 dropped:0 overruns:0 frame:0
>>> TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
>>> collisions:0 txqueuelen:1000
>>> RX bytes:1454 (1.4 Kb) TX bytes:10799 (10.5 Kb)
>>> arp looks good:
>>> sbin/arp
>>> Address HWtype HWaddress Flags
>>> Mask Iface
>>> 10.128.0.254 ether 00:00:5e:00:01:83 C eth
>>> 1
>>> 10.128.0.99 ether 00:04:96:6d:67:7f C eth
>>> 1
>>> 10.128.0.253 ether 00:04:96:15:5e:70 C eth
>>> 1
>>> 10.128.0.238 ether 00:04:96:27:50:63 C eth
>>> 1
>>> 10.128.0.244 ether 00:04:96:34:ea:f2 C eth
>>> 1
>>> 10.128.0.252 ether 00:04:96:28:24:ce C eth
>>> 1
>>> 10.128.0.237 ether 00:04:96:51:a8:8b C eth
>>> 1
>>> 192.168.127.254 ether 00:90:e8:4e:6e:4e C eth
>>> 0
>>> 10.128.0.251 ether 00:04:96:16:c7:50 C eth
>>> 1
>>> 10.128.0.249 ether 00:04:96:05:7a:13 C eth
>>> 1
>>> 10.128.0.247 ether 00:04:96:36:54:da C eth
>>> 1
>>> 10.128.0.246 ether 00:04:96:21:d6:10 C eth
>>> 1
>>> The firewall is disabled:
>>> systemctl status SuSEfirewall2.service
>>> SuSEfirewall2 phase 2
>>> Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
>>> Active: inactive (dead)
>>> But when he tries to telnet from the Linux box it times out:
>>> Trying 192.168.127.254...
>>> telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection
>>> timed out
>>> Any ideas what could be causing this?
>>> Thanks,
>>> Mark
>> << Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
>> << This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
> Christophe Haquin
> Control and Real Time systems Engineer
> +33 231454661 office
> +33 231454728 fax
> SdA/GIM
> GANIL
> Bd Henri Becquerel BP 55027
> 14076 CAEN CEDEX5
> Préservons notre environnement, n'imprimez ce mail que si nécessaire.
> Preserve our environment, print this email only if necessary.
- problem connecting serial device with moxa 5150A Sunny Badkul
- RE: problem connecting serial device with moxa 5150A Mark Rivers
- Re: problem connecting serial device with moxa 5150A Luca Cavalli
- Re: problem connecting serial device with moxa 5150A haquin
- Re: problem connecting serial device with moxa 5150A Martin L. Smith
Re: problem connecting serial device with moxa 5150A Kevin Peterson
<2017>
2025
2026
RE: problem connecting serial device with moxa 5150A freddie.akeroyd
<2017>
2025
2026
