Subject: RE: problem connecting serial device with moxa 5150A
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 24 Jan 2017 14:41:34 +0000
Hi Mark,
When you say "arp looks good" did you also mean the  HWaddress   listed there for 192.168.127.254   matches that written on the moxa? I think you may be able to restrict access on the moxa itself by IP address, maybe that has been configured to only allow the windows box at the moment?
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 24 January 2017 13:33
To: Sunny Badkul; [email protected]
I'm trying to help Sunny to connect from Linux to a serial port on a Moxa box.  It is not working, and I am stumped, so any ideas are welcome.
 From Windows he can telnet to it:
> when I telnet from windows
> telnet 192.168.127.254 4001
> It prompts a blank screen and for other IP or ports like 192.168.127.254 5064, 192.168.127.34 4732 etc. it simply says host not available so I think port 4001 should be good.
When he connects it to Linux he can ping it:
ping 192.168.127.254
PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255 time=1.69 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255 time=0.797 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255 time=0.753 ms
ifconfig looks OK:
eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
          inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
          inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
          TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
arp looks good:
sbin/arp
Address                  HWtype  HWaddress           Flags Mask            Iface
10.128.0.254             ether   00:00:5e:00:01:83   C                     eth1
10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth1
10.128.0.253             ether   00:04:96:15:5e:70   C                     eth1
10.128.0.238             ether   00:04:96:27:50:63   C                     eth1
10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth1
10.128.0.252             ether   00:04:96:28:24:ce   C                     eth1
10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth1
192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth0
10.128.0.251             ether   00:04:96:16:c7:50   C                     eth1
10.128.0.249             ether   00:04:96:05:7a:13   C                     eth1
10.128.0.247             ether   00:04:96:36:54:da   C                     eth1
10.128.0.246             ether   00:04:96:21:d6:10   C                     eth1
The firewall is disabled:
 systemctl status SuSEfirewall2.service
SuSEfirewall2 phase 2
   Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
   Active: inactive (dead)
But when he tries to telnet from the Linux box it times out:
Trying 192.168.127.254...
telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection timed out
Any ideas what could be causing this?
problem connecting serial device with moxa 5150A Sunny Badkul
RE: problem connecting serial device with moxa 5150A Mark Rivers
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: Re: problem connecting serial device with moxa 5150A Matt Newville
