Subject: RE: problem connecting serial device with moxa 5150A
To: "'Sunny Badkul'" <[email protected]>
Date: Fri, 27 Jan 2017 15:48:14 +0000
Hi Sunny,
What you have said makes no sense to me at all.
These are the IP settings on the Moxa box:
IP address                     : 192.168.127.254
Netmask                        : 255.255.255.0
Gateway                        :
These are the Windows IP settings when you boot Windows on the PC:
   Connection-specific DNS Suffix  . : cat.ernet.in<http://cat.ernet.in><http://cat.ernet.in>
   Link-local IPv6 Address . . . . . : fe80::f160:7b80:19a6:5bf2%11
   IPv4 Address. . . . . . . . . . . : 10.128.1.35
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . : 10.128.0.254
These are the Linux IP settings when you boot Linux on the PC:
eth0      Link encap:Ethernet  HWaddr D8:CB:8A:9C:61:96
          inet addr:192.168.127.0  Bcast:192.168.127.255  Mask:255.255.255.0
          inet6 addr: fe80::dacb:8aff:fe9c:6196/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
          TX packets:63 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1454 (1.4 Kb)  TX bytes:10799 (10.5 Kb)
eth1      Link encap:Ethernet  HWaddr 70:62:B8:B5:AE:FB
          inet addr:10.128.2.69  Bcast:10.128.255.255  Mask:255.255.0.0
          inet6 addr: fe80::7262:b8ff:feb5:aefb/64 Scope:Link
          RX packets:69794 errors:0 dropped:1 overruns:0 frame:0
          TX packets:16282 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:28074872 (26.7 Mb)  TX bytes:2245798 (2.1 Mb)
When you boot Linux you are connecting the Ethernet cable to the eth0 port, not the eth1 port as judged by the arp output, packet counters, and logic.
Notice that your Windows IP address and netmask are completely incorrect for the Moxa.  They have different subnet masks, and they are not on the same subnet.  But you say you can telnet to the Moxa OK from Windows.  That does not make sense to me.  I would actually expect that it would fail on Windows and succeed on Linux given these settings, but you are seeing the opposite.  Are you sure that you have actually connected the Moxa to that Ethernet interface and not another one?  When you change from Windows to Linux are you leaving the Ethernet cable plugged into the same port on the PC?
Please send the complete output of the following commands on Windows when it is connected OK to the Moxa
ipconfig /all
arp –a
Sent: Friday, January 27, 2017 8:15 AM
To: Mark Rivers
Hello,
   It is a dual boot machine in which 1 OS run at a time..
The moxa board is directly connected to the system with simple ethernet cable..
As u asked about power cycling when I swithch from windows to linux
1} I turned off moxa board and turn it on when connected to linux.
2} I kept moxa board turned on when switching on the OS.
In both cindition result is same ( I did not press reset buttion in both condions).
 Thank you
On 27 Jan 2017 6:38 p.m., "Mark Rivers" <[email protected]> wrote:
Please answer all the questions in my e-mail.  You did not not answer about power-cycling and about how the Moxa is physically connected to the machine.  Also, is this a dual boot machine, or are both OS running at the same time in a Virtual Machine?
Sent: Friday, January 27, 2017 7:02 AM
To: Mark Rivers
Subject: Re: problem connecting serial device with moxa 5150A
hi Mark,
outpot is same for ncat with port definition
ncat  192.168.127.254 4001
Ncat: Connection timed out.
> Ethernet adapter Local Area Connection 2:
this is the only Ethernet adapter which is connected to moxa in my machine, I left the second adapter disconnected when running ipconfig
Both the OS are running on same machine and I tried  both the methods power of the moxa when disconnecting to Linux and do no power off)
yes I tried to connect web interface both in linux and windows. its connected in windows and timed out in linux.
On Fri, Jan 27, 2017 at 5:13 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Hi Sunny,
You did not give the port 4001 in the ncat command.  It must be
That is the wrong Ethernet adapter, it is not the one on the same subnet as device (192.168.127.*).  Send the information on the port connected to the Moxa.
>> When you switch to Linux do you power-cycle the Moxa?  You should to make sure it has forgotten about the Windows machine
> I cant properly understand what you mean by this sentences. Please elaborate it.
You said that you can telnet to the Moxa from Windows.  When you then try to telnet from Linux did you turn off the power to the Moxa before you tried to connect from Linux.  Are the Linux and Windows computers actually the same computer with dual boot, or is it 2 different computers?
Have you tried using the Web interface to the Moxa in both Windows and Linux?
How is the Moxa connected to the Windows and Linux machines?  Direct connect, or through a switch?
From: Sunny Badkul [[email protected]<mailto:[email protected]>]
Sent: Friday, January 27, 2017 2:27 AM
To: Mark Rivers
Dear Mark,
 I tried All  five suggestions in your last mail
-          When you boot Windows what it the IP address of the Windows machine on that subnet?
Tunnel adapter Teredo Tunneling Pseudo-Interface:
   Media State . . . . . . . . . . . : Media disconnected
-          If you telnet from Windows can you type a command to the device and get a reasonable response.
Yes I can cammand the device with telnet and can put/get Input/outpot and alter the device functions.
-          When you switch to Linux do you power-cycle the Moxa?  You should to make sure it has forgotten about the Windows machine
-          Try running ncat from Linux to the Moxa rather than telnet.  See if that will connect.
result is same as telnet
-          Have you tried the Linux IOC again?  Perhaps some things we have done will have fixed it?
Yes I tried it continuously result is same.
I also disabled selinux prior it was permissive
following is the complete setting of moxa board with telnet in windows.
Model name       : NPort 5150A
MAC address      : 00:90:E8:4E:6E:4E
Serial No.       : 5227
Firmware version : 1.2 Build 15041515
System uptime    : 0 days, 01h:17m:25s
<< Main menu >>
  (1) Basic settings
  (2) Network settings
  (3) Serial settings
  (4) Operating settings
  (5) Accessible IP settings
  (6) Auto warning settings
  (7) Monitor
  (8) Ping
  (9) Change password
  (a) Load factory default
  (v) View settings
  (s) Save/Restart
  (q) Quit
Key in your selection: v
Server name                    : NP5150A_5227
Web console                    : Enable
Telnet console                 : Enable
Reset button protect           : No
Press any key to continue...
Gateway                        :
IP configuration               : Static
DNS server 1                   :
DNS server 2                   :
SNMP                           : Disable
SNMP community name            : public
SNMP contact                   :
SNMP location                  :
Auto report to IP              : 4001
Auto report to UDP port        : 4002
Auto report period(seconds)    : 10
Port 1
Baud rate                      : 9600
Data bits                      : 8
Stop bits                      : 1
Parity                         : None
Flow control                   : RTS/CTS
FIFO                           : Disable
Interface                      : RS-232
Port 1                         : TCP Server Mode
TCP alive check time (0-99min) : 70
Inactivity time                : 0
Max connection                 : 1
Packing length                 : 0
Delimiter 1                    : (Disable) 0
Delimiter 2                    : (Disable) 0
Delimiter process              : Do Nothing
Force transmit                 : 0
Local TCP port                 : 4001
Command port                   : 966
Enable the accessible IP list  : Disable
1       Disable                         0.0.0.0
2       Disable                         0.0.0.0
3       Disable                         0.0.0.0
4       Disable                         0.0.0.0
5       Disable                         0.0.0.0
6       Disable                         0.0.0.0
7       Disable                         0.0.0.0
8       Disable                         0.0.0.0
9       Disable                         0.0.0.0
10      Disable                         0.0.0.0
11      Disable                         0.0.0.0
12      Disable                         0.0.0.0
13      Disable                         0.0.0.0
14      Disable                         0.0.0.0
15      Disable                         0.0.0.0
16      Disable                         0.0.0.0
Mail server                    :
My server requires authenticat : Disable
From account address           : NP5150A_5227@NP5150A
Email address 1                :
Email address 2                :
Email address 3                :
Email address 4                :
SNMP trap server IP or domain  :
                        Mail    Trap
Cold start              Disable Disable
Warm start              Disable Disable
Authentication failure  Disable Disable
IP address changed      Disable
Password changed        Disable
DCD changed
Port    Mail    Trap
 1      Disable Disable
DSR changed
Port    Mail    Trap
 1      Disable Disable
On Tue, Jan 24, 2017 at 10:25 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Hi Sunny,
There have now been lots of suggestions on tech-talk.
Here are some questions and things to try:
Sent: Tuesday, January 24, 2017 7:35 AM
To: Sunny Badkul
On the Linux box can you run a browser (Firefox, etc.) and connect to the Moxa?
From: Sunny Badkul [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>]
Sent: Tuesday, January 24, 2017 6:35 AM
To: Mark Rivers
sorry,
          But output is same for this command also.
 telnet 192.168.127.254 4001
Trying 192.168.127.254...
telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection timed out
cant get whats wrong..
Thanx
On Tue, Jan 24, 2017 at 5:41 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
> after that I tried ping and telnet. it is same as before. When trying to telnet it tries for some
> time  and then time out. output for all commands is as follows..
> telnet: connect to address 192.168.127.254<http://192.168.127.254>: Connection timed out.
But you are not using telnet to the correct port.  The command should be
Sent: Tuesday, January 24, 2017 12:27 AM
To: Mark Rivers
hi Mark,
 I turned off the firewall and chacked the status with tha command
 systemctl status SuSEfirewall2.service
It reflects..
SuSEfirewall2 phase 2
   Loaded: loaded (/usr/lib/systemd/system/SuSEfirewall2.service; disabled)
   Active: inactive (dead)
after that I tried ping and telnet. it is same as before. When trying to telnet it tries for some time  and then time out. output for all commands is as follows..
ping 192.168.127.254
PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data.
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=1 ttl=255 time=1.69 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=2 ttl=255 time=0.797 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=3 ttl=255 time=0.753 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=4 ttl=255 time=0.724 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=5 ttl=255 time=0.804 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=6 ttl=255 time=0.795 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=7 ttl=255 time=0.713 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=8 ttl=255 time=0.769 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=9 ttl=255 time=0.810 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=10 ttl=255 time=0.770 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=11 ttl=255 time=0.692 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=12 ttl=255 time=0.849 ms
64 bytes from 192.168.127.254<http://192.168.127.254>: icmp_seq=13 ttl=255 time=0.739 ms
^C
--- 192.168.127.254 ping statistics ---
13 packets transmitted, 13 received, 0% packet loss, time 12000ms
rtt min/avg/max/mdev = 0.692/0.839/1.694/0.250 ms
/sbin/ifconfi
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:128 errors:0 dropped:0 overruns:0 frame:0
          TX packets:128 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:10432 (10.1 Kb)  TX bytes:10432 (10.1 Kb)
/sbin/arp
Address                  HWtype  HWaddress           Flags Mask            Iface
10.128.0.254             ether   00:00:5e:00:01:83   C                     eth1
10.128.0.99              ether   00:04:96:6d:67:7f   C                     eth1
10.128.0.253             ether   00:04:96:15:5e:70   C                     eth1
10.128.0.238             ether   00:04:96:27:50:63   C                     eth1
10.128.0.244             ether   00:04:96:34:ea:f2   C                     eth1
10.128.0.252             ether   00:04:96:28:24:ce   C                     eth1
10.128.0.237             ether   00:04:96:51:a8:8b   C                     eth1
192.168.127.254          ether   00:90:e8:4e:6e:4e   C                     eth0
10.128.0.251             ether   00:04:96:16:c7:50   C                     eth1
10.128.0.249             ether   00:04:96:05:7a:13   C                     eth1
10.128.0.247             ether   00:04:96:36:54:da   C                     eth1
10.128.0.246             ether   00:04:96:21:d6:10   C                     eth1
On Mon, Jan 23, 2017 at 6:33 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>> wrote:
With the firewall off and the Moxa running do the following:
- ping the Moxa from Linux
- Try to telnet to the Moxa
Then send the output of ifconfig and arp again.
Sent: Monday, January 23, 2017 6:07 AM
To: Mark Rivers
Now I stopped firewall with following YaSt > firewall> stop running firewall. And tried telnet again it timed out.
On Mon, Jan 23, 2017 at 5:16 PM, Sunny Badkul <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
and this is the output for command /sbin/arp when connecting the moxa
On Mon, Jan 23, 2017 at 4:39 PM, Sunny Badkul <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
hello Mark,
following is the outputs of commands u asked.
Yes Firewall is runnibg on my machine
/sbin/ifconfig
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 b)  TX bytes:8881 (8.6 Kb)
          RX packets:15552 errors:0 dropped:1 overruns:0 frame:0
          TX packets:3653 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5579991 (5.3 Mb)  TX bytes:438187 (427.9 Kb)
          RX packets:130 errors:0 dropped:0 overruns:0 frame:0
          TX packets:130 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:10628 (10.3 Kb)  TX bytes:10628 (10.3 Kb)
/sbin/arp
with Regards
Sunny
On Fri, Jan 20, 2017 at 6:05 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>> wrote:
The Moxa snapshots look OK to me.
I apologize, I missed this part of your previous message:
> I am using two OS in my machine opensuse as well as windows
> when I telnet from windows
> It promts a blank screen and for other IP or ports like 192.168.127.254 5064, 192.168.127.34 4732 etc. it simply says host not available so I think port 4001 should be good.
I agree, that means port 4001 should be good.  It means the problem is probably on Linux.
> but when I run telnet 192.168.127.254 4001 or telnet 192.168.127.254 or telnet 192.168.127.254 5064 from linux it tries for some time and the times out.
Can you send the output of "/sbin/ifconfig" and /sbin/arp on your Linux machine.
Is your Linux machine running a firewall?
Sent: Friday, January 20, 2017 1:04 AM
To: Mark Rivers
HIi Mark,
              these attachments  are snapshots for my moxa board with windows utility.
please check it and help me to resolve this.
thank you
On Thu, Jan 19, 2017 at 6:28 PM, Mark Rivers <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>> wrote:
Hi Sunny,
I don't know how to interpret this information because I don't know what operating mode 10 is, for example.
[Operating Mode]
Port1=10
[Operating Mode Option 2]
Port1=16,0x00,0x00,0,0
[Operating Mode Option 1]
Port1=0,7,1,4001,966,0,0
It does seem like port 4001 is correct.
Can you send a screen shot showing the Moxa configuration screen with operating mode, etc.
From: Sunny Badkul [[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>><mailto:[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>>>>]
Sent: Thursday, January 19, 2017 1:18 AM
To: Mark Rivers
hi Mark.
this is the configuration setting for my moxa board.
[NPort Configuration File]
CheckCode=cfg2
[Basic Information (not changeable)]
APID=0x80015100
HWID=0x515A
Serial No=5227
MAC Address=00:90:E8:4E:6E:4E
Firmware version=0x1020000
[Basic Settings]
Server Name=NP5150A_5227
Time Zone=0
Time Zone index=0
Date_Year=100
Date_Month=11
Date_Day=30
Time_Hour=0
Time_Minute=44
Time_Second=1
Time_Milliseconds=0
Time Server=
Console Enabled=3
[Network Settings]
IP Address=192.168.127.254
Netmask=255.255.255.0
Gateway=
IP Configuration=0
DNS Server 1=
DNS Server 2=
[SNMP]
Enable SNMP=0
Community=public
Location=
Contact=
Trap=
[Mail]
Mail Server=
Mail Server Login=0
User Name=
Password=
From Address=NP5150A_5227@NP5150A
To Address1=
To Address2=
To Address3=
To Address4=
[Accessible IP List]
Enabled=0
Rule1=0,,
Rule2=0,,
Rule3=0,,
Rule4=0,,
Rule5=0,,
Rule6=0,,
Rule7=0,,
Rule8=0,,
Rule9=0,,
Rule10=0,,
Rule11=0,,
Rule12=0,,
Rule13=0,,
Rule14=0,,
Rule15=0,,
Rule16=0,,
[Serial]
Port1=9600,3,1,1,0,
[Operating Mode]
Port1=10
[Auto Warning]
Mail=0x0
Trap=0x0
[Port Auto Warning]
Port1=0x00,0x00
[IP Address Report]
Server=
Port=4002
Period=10
[Password]
Password=
LCM & Reset Protect=0
 help me please.
 Thanks
Sunny
problem connecting serial device with moxa 5150A Sunny Badkul
RE: problem connecting serial device with moxa 5150A Mark Rivers
Re: problem connecting serial device with moxa 5150A Sunny Badkul
Prev: RE: Questions about set parameters to device by using epics Mark Rivers
Next: monitor subscription in areaDetector Pearson, Matthew R.
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: Re: problem connecting serial device with moxa 5150A Priller, John
