Subject: monitor subscription in areaDetector
To: "[email protected] list" <[email protected]>
Date: Fri, 27 Jan 2017 17:25:56 +0000
In areaDetector, for when we append NDAttribute data to NDArray objects, we have a class that can set up monitors on PVs. When a monitor event happens we record the data for use by the next NDArray object. However, we were setting a monitor callback handler for every connection event. This can result in multiple monitors being setup if the IOC that hosts the PV being monitored has been restarted a few times (resulting in a multiple connection events in the areaDetector IOC).
I was able to fix this in the same was as camonitor.c handles this, by using a flag to indicate that we’ve already connected (and set up a monitor) to a PV. Is this the most appropriate method to handle this? In the CA reference manual I see that there are functions like ca_clear_channel() and ca_clear_subscription() that we could possibly use on a disconnection event.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: monitor subscription in areaDetector Kasemir, Kay
Re: monitor subscription in areaDetector Andrew Johnson
Prev: RE: problem connecting serial device with moxa 5150A Mark Rivers
Next: Re: monitor subscription in areaDetector Kasemir, Kay
Prev: RE: Questions about set parameters to device by using epics Mark Rivers
