Hi Matt,
On 01/27/2017 11:25 AM, Pearson, Matthew R. wrote:
> In areaDetector, for when we append NDAttribute data to NDArray
> objects, we have a class that can set up monitors on PVs. When a
> monitor event happens we record the data for use by the next NDArray
> object. However, we were setting a monitor callback handler for every
> connection event. This can result in multiple monitors being setup if
> the IOC that hosts the PV being monitored has been restarted a few
> times (resulting in a multiple connection events in the areaDetector
> IOC).
A very common bug in CA client code unfortunately, the client library
API makes this mistake easy to make.
> I was able to fix this in the same was as camonitor.c handles this,
> by using a flag to indicate that we’ve already connected (and set up
> a monitor) to a PV. Is this the most appropriate method to handle
> this? In the CA reference manual I see that there are functions like
> ca_clear_channel() and ca_clear_subscription() that we could possibly
> use on a disconnection event.
Given that reconnection happens automatically inside the CA library and
you usually want that to happen, it's generally a bad idea to clear your
subscriptions just because a channel disconnects. However the connection
handler may need to make sure that the channel's native data type hasn't
changed since the last time it connected. If the client's code assumes
that the subscription always uses the channel's native type then the
connection handler will have to clear and resubscribe if the type
changes, but some clients may always subscribe with a specific data
type, in which case they won't need to worry about that.
- Andrew
- monitor subscription in areaDetector Pearson, Matthew R.
Re: monitor subscription in areaDetector Kasemir, Kay
答复: Questions about set parameters to device by using epics lzf neu
<2017>
2025
2026
macro question Rolf Keitel
<2017>
2025
2026
