1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem installing PyEpics
Date: Mon, 30 Jan 2017 18:34:26 -0600
Hi Andrew,
On Mon, Jan 30, 2017 at 4:15 PM, Andrew Johnson <[email protected]> wrote:
Hi Matt,
On 01/30/2017 03:09 PM, Matt Newville wrote:
> A larger-scale question would be:  why do libca.so and libCom.so need to
> be linked against libreadline? I would have thought that readline would
> be something that iocsh needs, but not libca / libCom.
The core of iocsh is a part of libCom.
It is possible to build Base with readline disabled, but on Linux that
configuration is not the default since readline comes with all Linux
distributions. The switch to turn it off is to comment out all of the 3
lines which set COMMANDLINE_LIBRARY in the appropriate file
  configure/os/CONFIG_SITE.Common.<host-arch>
or to set that variable to EPICS. Note that you have to rebuild libCom
for this change to take effect.
- Andrew
Ah, thanks.   I've always assumed that on *nix systems that there will be a libca.so and libCom.so available, and that it can be used by python.  But the increase in popularity of non-system-provided Python distributions such as Anaconda can cause the sort of trouble Allan saw, because that may be using a conflicting dynamic library than the one used to build libca/libCom. In practice, it seems like only readline that causes the trouble.
This may be a good reason to reconsider providing pre-built libca.so and libCom.so for linux and MacOSX, as we do for Windows, at least for Anaconda Python.
--Matt
Problem installing PyEpics Alan Kastengren
Re: Problem installing PyEpics Pete Jemian
Re: Problem installing PyEpics Matt Newville
Re: Problem installing PyEpics Andrew Johnson
Prev: Re: Problem installing PyEpics Andrew Johnson
Next: How to write multi value in a caput message? PilkyuJung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem installing PyEpics Vodopivec, Klemen
