Subject: Re: MCB-4B Motor WriteInt32 Errors
To: Caleb Marshall <[email protected]>
Date: Wed, 8 Feb 2017 17:38:47 +0000
Please send the following:
- Complete output when the IOC boots and runs for 10 seconds or so after iocInit.
- Output of the command
  asynReport 10 myPort
where myPort is the name you assigned to the motor controller port you created.
Sent from my iPhone
> On Feb 8, 2017, at 7:28 AM, Caleb Marshall <[email protected]> wrote:
> Hello all,
> I have been trying to develop a stepper motor control system using the Base release R3.15.2 and SynApps_5_8. I have followed the documentation in the motor record to setup the IOC for the MCB-4B controller board. Using the IO traces I can tell that communication with the board is happening (there is a constant polling of position and responses from the board, etc.), but whenever I try to change a value for a motion field I get the following:
> 2017/02/08 10:53:40.203 devMotorAsyn::asynCallback: Enge:m1 pasyn{Float64,Int32}->write returned
> 2017/02/08 10:53:40.203 asynMotorController:writeInt32 error, status=3 axis=0, function=4, value=0
> And the move command is never sent. I can update fields that do not require communication with the board however.
> Any ideas what could be going wrong?
> -Caleb Marshall
> NCSU/TUNL
Re: MCB-4B Motor WriteInt32 Errors Caleb Marshall
Prev: MCB-4B Motor WriteInt32 Errors Caleb Marshall
Next: Re: [epics-modules/asyn] Throw exception if we can't register interfaces (#43) Eric Norum
Next: Re: MCB-4B Motor WriteInt32 Errors Caleb Marshall
