Hi there,
I always run into a "Segmentation fault" in function "putFloatString" |
"putDoubleString" of BASE/src/db/dbConvert.c
When I comment out following lines (call of get_precision) everything is
working again:
3947
3948
4157
4158
Test system
Ubunu 16.04 (64 bit)
EPICS BASE 3.14.12.6 (64 bit)
To check the error, I used this code:
test.cpp
#include <malloc.h>
#include <cadef.h>
//#define DOUBLE
using namespace std;
int main() {
chid chanID;
int iNumber = 1;
int timeout = 0;
void *pValue = 0x0;
ca_context_create(ca_enable_preemptive_callback);
#if defined DOUBLE
pValue = (double*)malloc(iNumber*sizeof(double));
for(int i=0; i<iNumber; i++) {
((double*)pValue)[i] = (double)((1+i)*3.1415926535897);
#else
pValue = (float*)malloc(iNumber*sizeof(float));
((float*)pValue)[i] = (float)((1+i)*3.1415926535897);
#endif
ca_create_channel("caLab:waveString", 0, 0, 50, &chanID);
timeout = 3000;
while(ca_state(chanID) != cs_conn && timeout--) {
epicsThreadSleep(.001);
#if defined DOUBLE
ca_array_put(DBR_DOUBLE, 1, chanID, pValue);
#else
ca_array_put(DBR_FLOAT, 1, chanID, pValue);
#endif
ca_context_destroy();
free(pValue);
return 0;
g++ -I/usr/local/epics/base-3.14.12.6/include/os/Linux
-I/usr/local/epics/base-3.14.12.6/include -O0 -g3 -Wall -c
-fmessage-length=0 -MMD -MP -MF"test.d" -MT"test.d" -o "test.o" "test.cpp"
g++ -L/usr/local/epics/base-3.14.12.6/lib/linux-x86_64 -o "test"
test.o -lCom -lca
Any advice to solve this issue?
Best regards
Carsten Winkler
PS Same problem in 32 bit systems
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Re: Archive-engine compiled for linux-arm (Raspberry Pi) Miguel
Re: Archive-engine compiled for linux-arm (Raspberry Pi) Kasemir, Kay
<2017>
2025
2026
Leybold Combivac IT23 Pierrick Hanlet
<2017>
2025
2026
