Subject: |
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit |
Carsten Winkler <[email protected]> |
To: |
Date: |
Tue, 21 Feb 2017 09:15:15 +0100 |
I forgot to give you the used db entry. Here it is:
record(waveform, "caLab:waveString")
field(DESC, "String waveform record")
field(NELM, 48)
field(FTVL, "STRING")
field (PINI, "YES")
field (PREC, 3)
Am 20.02.2017 um 15:40 schrieb Carsten Winkler:
> Hi there,
> I always run into a "Segmentation fault" in function "putFloatString" |
> "putDoubleString" of BASE/src/db/dbConvert.c
> When I comment out following lines (call of get_precision) everything is
> working again:
> 3947
> 3948
> 4157
> 4158
> Test system
> Ubunu 16.04 (64 bit)
> EPICS BASE 3.14.12.6 (64 bit)
> To check the error, I used this code:
> test.cpp
> #include <malloc.h>
> #include <cadef.h>
> //#define DOUBLE
> using namespace std;
> int main() {
> chid chanID;
> int iNumber = 1;
> int timeout = 0;
> void *pValue = 0x0;
> ca_context_create(ca_enable_preemptive_callback);
> #if defined DOUBLE
> pValue = (double*)malloc(iNumber*sizeof(double));
> for(int i=0; i<iNumber; i++) {
> ((double*)pValue)[i] = (double)((1+i)*3.1415926535897);
> #else
> pValue = (float*)malloc(iNumber*sizeof(float));
> ((float*)pValue)[i] = (float)((1+i)*3.1415926535897);
> #endif
> ca_create_channel("caLab:waveString", 0, 0, 50, &chanID);
> timeout = 3000;
> while(ca_state(chanID) != cs_conn && timeout--) {
> epicsThreadSleep(.001);
> #if defined DOUBLE
> ca_array_put(DBR_DOUBLE, 1, chanID, pValue);
> #else
> ca_array_put(DBR_FLOAT, 1, chanID, pValue);
> #endif
> ca_context_destroy();
> free(pValue);
> return 0;
> g++ -I/usr/local/epics/base-3.14.12.6/include/os/Linux
> -I/usr/local/epics/base-3.14.12.6/include -O0 -g3 -Wall -c
> -fmessage-length=0 -MMD -MP -MF"test.d" -MT"test.d" -o "test.o" "test.cpp"
> g++ -L/usr/local/epics/base-3.14.12.6/lib/linux-x86_64 -o "test"
> test.o -lCom -lca
> Any advice to solve this issue?
> Best regards
> Carsten Winkler
> PS Same problem in 32 bit systems
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Postadresse:
D-14109 Berlin
- Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Ralph Lange
- Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Re: Archive-engine compiled for linux-arm (Raspberry Pi) Florian Feldbauer
<2017>
2025
2026
<2017>
2025
2026
