Hi Carsten, The default value for precision used when you comment out the lines you mention is 6. Can you achieve the same (i.e. avoid segfaults) by setting PREC to 6 in your database? If yes: which PREC values cause segfaults? Cheers, ~Ralph On Tue, Feb 21, 2017 at 9:15 AM, Carsten Winkler <[email protected]> wrote: I forgot to give you the used db entry. Here it is:
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
