Perfect. Then I see no reason this should not work, in principle.
Carsten, apart from making sure that libCom etc can be unloaded safely,
which is probably not your core business, is there a way to execute code
before CA gets unloaded? Perhaps one could just kill the caRepeater there?
Am 23.02.2017 um 21:50 schrieb Hill, Jeff:
There are also a number of one-time allocations which aren't cleaned up.
More CA fixes needed?
The CA client library _is_ cleaning up all of its allocations if ca_context_destroy is explicitly called, but this is of course not universal for components in libCom and or EPICS base.
Jeff
-----Original Message-----
[email protected]] On Behalf Of Ben Franksen
Sent: Thursday, February 23, 2017 1:29 PM
To: [email protected]
Subject: Re: memory leak after unloading of ca.lib
Am 23.02.2017 um 18:26 schrieb Michael Davidsaver:
Personally, I'd never consider trying to unload libCom or libca.
Neither was designed with this in mind.
Carsten (and me) wouldn't either, it's just that Labview seems to insist
on it :-(
For example. With libCom the errlog thread is never stopped. And libca
registers a function pointer using epicsAtExit(). So if libca is
unloaded, then running epicsExit() will fail.
Perhaps there should be a way to unregister the epicsAtExit callback.
Cheers
Ben
On 02/23/2017 03:50 AM, Carsten Winkler wrote:
Hi there,
when your project (e.g. LabVIEW) uses dynamic loading and unloading of
channel access classes your main class will sometimes (at 64 bit nearly
always) crush with a segmentation fault. The reason seems to be missing
free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this
applies also to other EPICS Base versions).
I wrote a tiny test case to check it and it would be great to get any
advise to solve the issue.
Best regards
Carsten
Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
Forschungszentren e.V.
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr.
Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Postadresse:
D-14109 Berlin
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Postadresse:
D-14109 Berlin
- memory leak after unloading of ca.lib Carsten Winkler
- Re: memory leak after unloading of ca.lib Michael Davidsaver
- Re: memory leak after unloading of ca.lib Ben Franksen
- RE: memory leak after unloading of ca.lib Hill, Jeff
<2017>
2025
2026
<2017>
2025
2026
