1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater: Syntax error: ")" unexpected
To: <[email protected]>
Date: Wed, 17 May 2017 11:11:52 -0500
On 05/17/2017 10:14 AM, nb wrote:
> On 17.05.2017 17:37, Wang Xiaoqiang wrote:
>> Instead of cross-compiling, you can compile epics base on RPi as well.
> I ran make again and it compiled successfully in couple minutes. The
> only thing that changed in the system is that I installed
> libreadline-dev and swig (those were required to build pcaspy).
> Is any of those required for the EPICS base? I didn't see it in the
> dependencies.
libreadline-dev is optional. The default configuration of Base for the
linux-arm target assumes that it is not present, but if you have it you
can edit your base/configure/os/CONFIG_SITE.Common.linux-arm and adjust
the setting of COMMANDLINE_LIBRARY in there as appropriate. You will
have to do a 'make rebuild' inside src/libCom for that configuration
change to take effect.
swig it not used by Base.
- Andrew
caRepeater: Syntax error: ")" unexpected nb
Re: caRepeater: Syntax error: ")" unexpected nb
Prev: Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
Next: Re: Archiver appliance showing DESC field on pv details page Shankar, Murali
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
