On 17.05.2017 17:37, Wang Xiaoqiang wrote:
Instead of cross-compiling, you can compile epics base on RPi as well.
I ran make again and it compiled successfully in couple minutes. The
only thing that changed in the system is that I installed
libreadline-dev and swig (those were required to build pcaspy).
Is any of those required for the EPICS base? I didn't see it in the
dependencies.
Kind regards,
Nick
- Re: caRepeater: Syntax error: ")" unexpected Wang Xiaoqiang (PSI)
- Re: caRepeater: Syntax error: ")" unexpected Pete Jemian
- Re: caRepeater: Syntax error: ")" unexpected Andrew Johnson
- caRepeater: Syntax error: ")" unexpected nb
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
