Subject: Re: string fanout or stringout after conditional check?
To: "Zimoch Dirk (PSI)" <[email protected]>
Cc: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 May 2017 16:31:58 +0200
  For the closing purpose, I would like to reply this list.
I found the way to do what I need with aSub record. And I've learned other things than what I need as usual.
  Anyway, always thank you.
  Han
On 05/18/2017 11:39 PM, Zimoch Dirk (PSI) wrote:
The guard is not strictly necessary. StreamDevice will not overrun the buffer.
In recent versions I have improved string scanning: for example "%#s" reads strings containing white space.
But maybe you want to do more parsing:
in "user,%d,%(\$1)s";
This in an I/O Intr scanned record fetches the number whenever a line starting with "user," is received and sends the last part to a different record.
Dirk
Gruss
Dirk
Am 18.05.2017 um 17:22 schrieb Jeong Han Lee <[email protected]>:
Hi Eric,
On 05/18/2017 05:08 PM, Eric Norum wrote:
To guard against buffer overrun issues it’s best to specify a maximum
length in the protocol entry:
read_raw
  in “%39c";
 Thanks for your comments.
Or, if the input terminator is set to a single ‘\r’ or ‘\n’ and the
device sends a "\r\n” you could use:
read_raw
  in “%39[^\r\n]";
 By the way, I have the terminator in "st.cmd" as follows:
 asynOctetSetInputEos("L0", 0, "\r\n")
 Han
On May 18, 2017, at 6:37 AM, Jeong Han Lee <[email protected]
<mailto:[email protected]>> wrote:
I have the bar code scanner, so, the string input is the arbitrary
ascii and numbers from bar codes, generated by myself, whenever I scan
it.
For example,
case 1 : user,123456789,U002C007
case 2 : ABCDEFGHIZ0123456789
case 3 : office,248795493,M01B21
case 4 : ....
case N : SUBMIT
Note that case 1..N-1 can be done without order.
The scanner has a typical RS232 connection. I wrote the very simple
IOC with asyn and Stream. It has only one record and one function in
db and proto file as follows:
--- snip snip ---
record(stringin, "$(SYSDEV)RawScanData")
  field(DESC, "RAW Scanned data")
  field(DTYP, "stream")
  field( INP, "@scanner.proto read_raw $(PORT)")
  field(SCAN, "I/O Intr")
  field(PINI, "YES")
read_raw
  in "%s";
--- snip snip ----------
Is this enough?
 Han
Eric Norum
[email protected] <mailto:[email protected]>
string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Ralph Lange
Re: string fanout or stringout after conditional check? Jeong Han Lee
Re: string fanout or stringout after conditional check? Eric Norum
Re: string fanout or stringout after conditional check? Zimoch Dirk (PSI)
Prev: RE: Force TCP/IP reconnect from Asyn/Streamdevice Mark Rivers
Next: support for Thorlabs ODC001 D Peter Siddons
Prev: Re: string fanout or stringout after conditional check? Eric Norum
Next: EDM questions lzf neu
